| Computers and Networking Discuss computer and Networking related questions here! |
| I am trying to com. with much older robots. I have built cables, and re-built and re-checked cables between computer and controller. I still get same error code, which according to my manual means either, parity error,Over run error, or framing error. Now, I understand the parity error , and tried changing to all other parity options systematically, = no good. What I dont understand is what an over run or framing error is exactly? Could someone shed some light on this for me please? Then I may know which direction to go. Many thanks.
__________________ menomana |
| What is your baud rate set at? I had the same problem on some 6m controls and it worked with a slower baud rate? |
If for instance one is set to 6 data bits and the other 8 data bits, then a frame error will probabally result. Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| books say it should be 4800bps,even parity,7 bits 1 stop bit,basic protocal i set my com 1 port accordingly, built cables...and re-built cables... I also had to convert from a 25db connector to 9 pin on my computer (that's how old this technology is) I went to a web site a followed their diagram for converting 25 pin to 9 pin connector. So Now I have 9 pin on laptop, 25 pin on old controller. I thought I had made cable wrong, so I left off the connectors and just push the cable pins into the according spots on the recieving connectors (so I could move them arround if need be) I think the TXD and RXT signals are wrong in the manual? Is there a cheap serial interface detector to verify what signal is where? thanks
| If you have a newer pc the you should go into your advanved setting for you com port and turn off FiFo. There should be a tab for this. |
| I 'm starting to wonder if someone has messed with dip switches. I have no info on them, manufacteur will no longer support this system either, looking like i might have to gut the controlls to more modern system. I would really like to make sure I have exhausted all avenues before pulling the trigger on changing control hardware/software.
| Thanks for the advice, I will try a more modern laptop, as the one I am using is a dianasour. Maybe hyperterminal will be more successful.
| Hyperterminal is a pain in the A***, use the freebee from http://www.cadem.com before that, They also have all the pin outs for RS232 25 & 9 pin 'D'. Al
| thanks Al, I will try the freebee first.
#10
Jay |
#11
Al
#12
| Ok, is it safe to assume that the equipment he is using requires hardware handshaking? If so, that complicates things ![]() Jay |
| Could Bob CAD/CAM work with 6 axis robot?? | calkai1 | BobCad-Cam | 4 | 12-04-2008 07:42 AM |
| Robot arms and Digitizer | vacpress | RC Robotics & Autonomous Robots | 4 | 07-28-2004 05:05 AM |
