| Computers and Networking Discuss computer and Networking related questions here! |
| Need help installing windows 95 - cdrom wont read I formatted my windows 95 machine today. I am going to use it in dos mode to run Turbocnc for my homemade cnc router. I formatted it so that I could do a fresh install of Win95 as I knew I had lots of garbage on this machine that was know longer needed. I was able to formate the drive and reboot the system. From dos prompt, I can type in d: and it will give me a d: command prompt like it is recognizing the cd drive. When I type in dir to get a directory of whats on the disk (which is my win95 disk) it says that it cannot read from the drive. I thought that it was a bad drive and tried a spare that I had setting around and I got the same thing. Is it possible that I have 2 bad cd drives or am I missing something simple? Thanks Dan
__________________ Check out what I am working on at www.routerbitz.com! |
| Their may not be any drivers loaded that support your CD drive, do you have a install floppy disk? Did you create a dos partition and make it active?
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| Do you want to bother with windows if you just need dos, Paul posted the link to the MSDOS 7.1 a while ago http://newdos.yginfo.net/msdos71/index.htm It has a flash screen on boot up and allows long file names as well as a few utilities. You still have to high level format the HD as well as set a partition as has been stated. Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| try a win98 se bootdisk it has better cdrom drivers http://www.bootdisk.com/bootdisk.htm |
| Do I need Windows? Well I guess I really don't know. I am using a Windows XP machine in the house with TurboCad and will be using TurboCNC on my Garage machine to run the CNC router. What I need then is: 1. Some type of converter software to turn the cad drawings into G code. Any recommendations here? Should this be on the XP machine or Dos Machine? 2. A way to tranfer the files from the Xp Machine in the house to the dos machine in the shop. Will simple files fit on a floppy disk or will the file size be to big? That is the main reason why I wanted to get the cd rom working was to transfer files. Thanks all
| Go to bootdisk and look for a set of dos utils that will allow you too boot in dos with CD Rom support.
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| cnc control software for windows xp | Ralph Burge | General CNC (Mill and Lathe) Control Software (NC) | 6 | 05-28-2008 08:21 PM |
| New StarCam windows controller from Larken | routerman | StarCam CNC | 14 | 06-20-2007 12:43 PM |
| punch or read with fanuc | formulaz | G-Code Programing | 3 | 01-26-2005 10:10 PM |
| Windows XP or Windows 2000 better with Mach2 | Beezer | Mach Software (ArtSoft software) | 2 | 10-18-2004 11:08 AM |
