Results 1 to 11 of 11
Thread: Revenge repair on faulty HD (using tin snips).
    Registered ImanCarrot's Avatar
    Nov 2005
    UK
    You know when a faulty HArd Disk keeps dropping sectors and messing with your head?
    You try everything, losing valuable machining time while the HD keeps flashing write/ read errors and sniggering smugly at you?
    Well, I thought that on behalf of all of us frustrated and annoyed engineers I should teach mine a lesson... with a pair of tin snips
    Revenge is sweeet!
    Attached Thumbnails Attached Thumbnails Revenge repair on faulty HD (using tin snips).-image003.jpg   Revenge repair on faulty HD (using tin snips).-image004.jpg   Revenge repair on faulty HD (using tin snips).-image005.jpg   Revenge repair on faulty HD (using tin snips).-image006.jpg
    I love deadlines- I like the whooshing sound they make as they fly by.
    May 2006
    Thats what I call re-partitioning a hard disk!!! lol
    Russell.
    Registered ghyman's Avatar
    Feb 2005
    From the "just because" department...
    In the top-left corner of the HDD (in your pix) is the mechanism for positioning the heads. Pry that apart, and you will find two wicked-strong magnets therein.
    And by "wicked strong", I mean "will hold a phone book to a filing cabinet".
    Great fun.
    Registered Weldtutor's Avatar
    Oct 2005
    Arrow Teaching A Lesson!
    Quote Originally Posted by ImanCarrot View Post
    I hope it learned the lesson well, & works better for you, now that you have
    re-educated it!
    Is there a particular brand of tin snips to use, or do they all pretty much do the same job?
    Do you have any other computer repair techniques to share?
    Dec 2006
    Now,
    I want to see you defragment it.
    Nov 2005
    UK
    lmao! "defrag" where's my double sided tape and blu tak lol
    May 2006
    Hmm, I have just had my HDD on the PC controlling my router die, can I send it to you for "servicing"
    I know what you are thinking, that is a silly idea, postage woud be too much, oh well, going to check the "old school" toolbox for some tools to do the job myself, pics will follow...
    Russell.
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    a vise would work well
    then you can see how much you can actually compress the disc
    Feb 2006
    And I always thought a BIG hammer was the solution to everything
    Nov 2006
    Quote Originally Posted by ghyman View Post
    Great fun.
    I've heard that before.. that some of the strongest magnets are in hard drives. I wonder what they would need such a powerful magnet for?
    Mar 2007
    Hey, that looks like fun!!
    FYI: i have been using flash memory 4 some time now because of that. I discovered, if you have a 1 gig hard drive or bigger mounted to your machine somehow, if you always machine under 1500 rpms on the spindle, they do ok, but if you run 2-5,000 rpm, now your hard drive's days are numbered, and if you have a 10,000 rpm spindle, we busted a hard drive in 1 hour!!!!, no poop, we couldn't believe it, so 1 hour later, we busted another! Even if the spindle is just running, not even cutting anything! you can find flash hard drives if you search IDE to flash memory.
    1. dongle repair?
      By quemast in forum GibbsCAM
      Last Post: 12-24-2005, 01:33 PM
    2. gib repair
      By Runner4404spd in forum Benchtop Machines
      Last Post: 09-15-2005, 11:53 AM
    3. THK Bearing Repair
      By georgebarr in forum DIY CNC Router Table Machines
      Last Post: 01-13-2004, 03:36 AM
    4. Faulty stepper?
      By kong in forum DIY CNC Router Table Machines
      Last Post: 05-26-2003, 10:15 AM
