04-09-2006, 01:07 PM
MS in their wisdom didn't include any pen plotter drivers in XP or Win2k. The manufacturers including HP haven't provided drivers for XP since XP wasn't around when the pen plotters where replaced by inkjet.
You have several solutions;
Autocad has its own Plotter driver component and you can drive most older pen plotters from Autocad in any OS Autocad installs in. Works well but if you're producing iges or stl files theres a problem getting them into autocad and plotting with the correct line types, weights, layers, colours and with hidden line removal.
The second is a third party driver for win2k or XP, theres only one, WinLine - not readily available, not cheap but it does work well and does work from 3d software printing iges, stl etc. I've used it with rhino without problems. Can't justify the ~$160 for it at home though.
I've heard suggested that you can sometimes attach and install the plotter on a win98 machine so the printer is a native printer and transfer the XP/2k sourced files to the 98 machine and use the print file directly there. I've tried it and the problem here is that it only works with file formats the native printer recognises - hpgl, dxf, dwg etc. Works correctly about 50% of the time and probably 100% if you want to spend the time working what line types and layers needed and page scaling.
Finally the ideal solution is to get a driver written - but that's beyond me unfortunately...
Andrew |
