Results 1 to 6 of 6
Thread: Connection between UC232A and Haas VF CNC machine
    Feb 2012
    Hungary
    I am on a CNC out-of-school course. I have found cncsimulator to practice things.
    Our teacher decided as graduation, we will have the teacher's Haas VF (I think, I'll have to note the exact model tomorrow) to carve ourselves our self-designed (and self-programmed) nameplate.
    I'd like to have the CNC run off my own laptop/program. I think my netbook's cncsimulator could do it.
    So I purchased a UC232A USB-to-serial converter (google "aten", go to the product section, "usb converters" and it should be there). However, the converter converts from USB to DA9 (male). The CNC machine has a DB25 (female) port (and a floopy drive).
    I got got this converter not by direct choice, but because I asked the shopkeeper for a converter and had to order. I got a USB-to-DA9 that had a DA9-to-DB25 attached to it (so it would go unto to the CNC's DB25F). The DA9-to-DB25 has no markings of any kind on it.
    Question: can I make a connection between my computer with this converter with what I have?
    If not ,what converter should I try to get? I have seen another one, however for what is (for me) a hefty price. I may not have a chance to try and connect my laptop to the CNC machine tomorrow (when I go to my lesson).
    Feb 2009
    Well, first thing you will need is a communication program to load your program to the haas memory. You can download a trial version of multi dnc, it gives you 40 hours.
    Then you need a USB to 9 pin adapter for your laptop
    A 9 to 25 pin serial cable
    Then a db25 null modem adapter.
    Or you can make your own cable from 9 pin to 25 pin null modem cable.
    Then you need to match all the comm settings between your communications program and the haas controller.
    Feb 2012
    Hungary
    So this hardware CAN communicate with a CNC machine? Because that is what I really have to know.
    To repeat: I have a DA9-to-DB-25(male) converter already. Can my PC and a CNC machine communicate with each other with the above stated hardware?
    Feb 2009
    If the converter is null modem, yes. It's not just plug and play, you still need to set up parameters in the machine and pc.
    Feb 2012
    Hungary
    How can I be sure whether the convert (I'm guessing the SA9-to-USB in this case) is a null modem?
    Feb 2009
    Just search on here for haas rs232. About a hundred posts on here for communications.
    1. USB Wireless Connection for Tormach Machine Controller
      By anglin in forum Tormach Personal CNC Mill
      Last Post: 12-24-2011, 03:48 AM
    2. Need Help!- Haas 5C indexer connection/programming
      By artin5 in forum Haas Mills
      Last Post: 12-31-2010, 02:12 PM
    3. Need Help!- Connection layout of Fanuc Wire Cut machine
      By Namnp2007 in forum Fanuc
      Last Post: 08-13-2010, 08:19 PM
    4. Parallel Port machine controller to computer connection HELP PLEASE!
      By whipsnade in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 08-01-2006, 05:45 PM
