Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Computers and Networking
Computers and Networking Discuss computer and Networking related questions here!
Old 06-29-2010, 12:12 AM
larry53 is on a distinguished road
Ram Memory upgrade
I have a H.P. desktop computer that was made in 2006. It is suppose to be able to go to 8 gig. I have contacted H.P. and they also said it could go to 8 gig on the ram. It had 2 gig and I added another 2 gig on one memory stick. It then showed I had 3.5 gig. So I added one more gig and it still shows 3.5 gig. I went back to H.P. and ask what is the problem. They said to install the latest update to the Bios. Which I did, but still reads 3.5 gigs. Now H.P. tells me to get the Bios, Flashed and reinstalled by a computer shop. If I get this done, should the computer than show there is 5 gig or not. This computer was bought new and this is the first time he computer memory was upgraded. I would think that if it is sold as a computer that will go to 8 gig, then why do I have to take it to a computer shop and pay for what should already be there, or did the Bios change,causing this problem and it is not H.P. bull? Every time I have been on H.P. site they give a whole not of information that never does anything to help. Thanks Larry
Old 06-30-2010, 10:34 AM
JimBoyce is on a distinguished road
Get into the bios, find out the mother board manufaturer, and go to their website.
Also, what does the bios say about memory size.
Old 06-30-2010, 11:31 AM
The bios setup listed as follows: Installed memory 5120/pc2-5300
Memory banks, 1thruough 3 has 1024mb/DDR2 Sdram, bank 4 has 2048mb/DDR2 Sdram. I already had the bios updated by direction of H.P.
Old 07-03-2010, 02:11 PM
So the bios says 5 gig. What says you have 3.5 gig? Perhaps that is wrong.
Also you flashed the bios, that means you know more then 92.3% of computer shops and 99.9% of telephone support, which explains why you found out they are useless.
Old 07-03-2010, 04:23 PM
I click on my computer, then properites.
Old 07-03-2010, 08:30 PM
armstrong360 is on a distinguished road
Memory
Are you running a 32 bot version of windows? If so you will see somewhat less than 4 Gig. 32 bit windows can not use any more memory even if present in the machine...
Old 07-03-2010, 11:24 PM
Yes it is a 32 bit system, however this machine was special ordered from HP. According to HP this machine is set to go to max of 8 gig.
Old 07-04-2010, 08:08 AM
ger21's Avatar
Yes, the machine can hold 8 gigs of ram, but your version of Windows can't use it. If you want to use more than 3.5Gig, you need to use a 64 bit version of XP, Vista or 7. It's not the PC that is the problem, it's your version of XP. 32bit operating systems can only use 3.5Gigs of RAM.
Old 07-04-2010, 08:56 AM
wildwestpat is on a distinguished road
Hi Larry53
As is often the case there is a shed full of confusion when dealing with the combined effect of hardware and software and hard facts are difficult to come by. I think you have been given some clues but not the full answer by those help desk people. I would use one of the memory advisor software utilities such as that on the Crucial Memory site at :-
http://www.crucial.com/ballistix/index.aspx
If the automated answer is not good enough then for an insight into the possible use of more RAM I suggest you look at the following and wade through the Microsoft advice but consider memory leakage and the other bits I have included further on in this posting.
Limits for RAM access by the versions of Microsoft OS see:-
http://msdn.microsoft.com/en-us/libr...its_windows_xp
To add Physical Address Extension (PAE if supported by your hardware) see:-
http://msdn.microsoft.com/en-us/libr...8VS.85%29.aspx
Other things to consider are the use of the hard disc as a scratch pad to help with a temporary bottle neck in the use of RAM. (accessed via control panel - system - performance options/advanced/virtual memory - change - extend size of disc use ). A further point to watch is that you don't have applications running in the background or ones that have not released their use of RAM back into the pool (memory leakage). IMO disable all non essential programes in the start up menu and also check what is running using the widows task manager (ctr+alt+del) for a list including the percentage CPU use. There is a nasty feature in Windows that is often active by default that logs system problem and is part of the Microsoft automated help feature IMO disable along with the automatic updates of software and OS if and it is a very big IF you are certain that you do not need these features. IMO establish a backup routine that includes virus checks and update patches as well as archive of all data. There are various ways of implimenting this depending on your view of risk and consequential loss.
Hope this helps as the true limits are set by your hardware and the software settings in both the BIOS and the OS.
Regards - Pat
Last edited by wildwestpat; 07-04-2010 at 09:04 AM. Reason: Typos and Memory leakage and other pointers to need more RAM that may not be required.
Old 07-04-2010, 09:10 AM
Hi Larry 53
Just a thought but why are you looking to upgrade the RAM? Is it because RAM is cheaper now are you having speed issues?
You will by now have seen the problems in getting more RAM to be recognised let alone used by the machine. IMO look to the memory leakage issues and software that is loaded and running in the background. Consider isolating the CNC PC from the internet and turning off all virus and all program update options - virus check all CNC input prior to loading on a trusted networked machine.
Just my comments on how to keep the PC gremlins out of the workshop!
Regards - Pat
  #11   Ban this user!
Old 07-04-2010, 11:29 PM
I am not that good on changing any settings on the computer. The memory upgrade site does not show my model. The only information I have that this computer will go up to 8 gig and should accepted and read 8 gig is from HP. I talk to them and they had me to updated my bios. When this did not change anything they said I had to go to a computer shop and have them to reinstall my bios and flash the bios. I do not know what this means or even if it will help.
I am also not sure how a 32 bit windows xp computer can go to 8 gig. But HP said it would because it had what ever it needed to do so from the factory. My computer Model is a D4600Y Pavilion with XP installed. I am not even sure it is a 32 bit computer.
CPU usage= 0 to 1%, has jumped to 2%
PF usage= 515mb
  #12   Ban this user!
Old 07-05-2010, 08:22 AM
Hi Larry53
Yes HP are probably correct you could insert extra memory. BUT I question why? You will have to be running some 'special' software to be able to make use of any more as Microsoft Windows will not let you use any more. Roughly 2Gb to the operating system and 2Gb for program running. I am guessing that HP have been at the BIOS and have added PAE - see the Microsoft site I gave you a link for. This also requires the options set in the msconfig but again you would not notice any enhancement in speed unless the software you are running can make use of it.
You should be able to find the computer listed on the site I pointer out for you if not try the automated tool at:-
http://www.crucial.com/store/drammemory.aspx
The problem is that during a production run some manufacturers use a variety of mother boards and processors but still have the same type and model number of the label.
With your hardware being four years old you need to ensure that you have the correct type of memory and I would advise that you stick to the same type and speed for all slots. Look at the mother board RAM instructions as this will give any pairing restrictions and slot position restrictions.
Also IMO you need to be sure that you are not having memory leakage due to previously rum software not releasing memory back into the pool when you have closed it down. (Try powering off - wait 10 seconds - power up - let the Windows stabilise this can take minutes if you have loads of junk in the registry files - then press control + alt + delete keys to bring up the windows task manager. This will show the applications running and under the processes flag the memory and CPU usage of files that have been opened and have the potential to use memory. Also under the performance flag the amount of CPU power you are using - with nothing running this should be very low i.e. one or two percent or less.
I still question why you are wanting to add another 4Gb of RAM as Windows XP 32 bit can't make any use of it although the BIOS could at the hardware level. This means that you would not see any improvement in running WINDOWS based software.
Because over time users tend to clutter up the registry with programs that have been down loaded - tried - then removed. Unfortunately this can leave some settings on the machine that allocate memory to the removed software. Four years is more than enough time for a machine that is in general / family use to have accumulated a lot of broken links and memory settings in the registry to cause slow running. Editing the Registry files is not for the uninitiated and is best done by making a fresh install of WINDOWS on a new or reformatted hard disc. There are other options such as making a new partition but again this requires some experience. Just make sure you have the necessary serial numbers and discs to reload the machine if you reformat the hard disc.
Just re-read your post. Reflashing the BIOS is again not for the uninitiated so do NOT do this unless you are sure of what you are doing. I have tried and find that the Crucial Memory selector does not go back far enough to list your computer - try calling them for advice. However I do think you will see any advantage in any extra RAM unless you upgrade your OS but i suspect you would get some speed increase by making a fresh install.
Regards - Pat
PS I have just read the spec for your PC and yes it can take upto 8Gb of RAM - but - there is a foot note to the 8Gb that states that this may not be available and since you are not running a moder OS this means that your configuration can not use the extra RAM. Try ooking at :-
http://h10025.www1.hp.com/ewfrf/wc/d...roduct=3239108
as HP have set out the steps to cleaning up a machine just short of a fresh install.
Last edited by wildwestpat; 07-05-2010 at 08:50 AM. Reason: Added foot note on Model not able to make use of any more than 4Gb of RAM from HP web site for this computer.
16M memory upgrade 1ctoolfool Haas Mills 6 04-26-2010 06:32 AM
memory upgrade conklin36 Controller & Computer Solutions 0 02-07-2010 10:04 AM
Fanuc 3T Memory Upgrade? NID Fanuc 1 12-16-2009 01:04 PM
TNC150 memory upgrade? Oviksnc Bridgeport and Hardinge Mills 3 09-27-2007 11:52 PM
1985 VMC-40 OS and Memory upgrade 2001lightning Fadal 4 10-12-2005 10:53 AM
