| Computers and Networking Discuss computer and Networking related questions here! |
| I have a computer that I just loaded with DOS 6.22 because my control software requires it. Now I can't access my Cd-Rom, I get an invalid drive error when I try. I know it works because I just had Windows 98 on it before I reformatted it and loaded it with DOS and the Cd-Rom worked fine. I could use any advice you may have. Thanks-Robbie |
| does the config.sys and autoexec.bat have any drivers loaded? |
| You need the CDROM driver in config.sys file: DEVICE=CDROM.SYS .... or something similar. If not available, search the net for generic driver. Then you need the CDROM dos extension line in AUTOEXEC.BAT: MSCDEX.EXE .... or something along this line. Or just go to http://www.bootdisk.com and find a suitable boot disk there
__________________ Stupid questions make me smarter... See how smart I've become at www.9w2bsr.com ;-P |
| Hey guys, Thanks for your replies. Im not to experienced with DOS. Can I edit the config.sys and AUTOEXEC.BAT file and add those lines or do I need to do something more, Thanks-Robbie |
| You can just edit them and type in the lines.
| Off course making sure the additional files are there Just adding the statements without the actual files won't change anything (except given error messages)
| If I do need the files, Do I just find them on the internet and copy them to the hard drive. Thanks for all your quick answers. |
| IF you have windows 98 the win98 startup disk has the generic cdrom driver together with the changes you'd need to make to the autoexec bat and config sys, |
#10
| I tried adding the lines and I got the error message saying I needed the driver. I went to bootdisk.com and downloaded the bootdisk for DOS 6.22 and wrote it to a floppy. I was wondering would all I have to do is copy MSCDEX.EXE file to the hard drive or do I have to do something else? Thanks- Robbie |
#11
| Copy MSCDEX.com to the hard drive or indicate where it is with the Path command. This is another site that shows how http://www.pcguide.com/proc/setup/cddriver-c.html Also go to the web site of the CD drive maker and see if there is a driver available. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
#12
| I got my cdrom drive to work under DOS thanks to your guys help. It put the driver letter to R:. Is there any way to designate another letter like D: under DOS. If so how would I go about doing that. Thanks-Robbie |
| Driving a 4 pole ac servo with a 6 pole drive | TommyB | Servo Motors and Drives | 4 | 04-28-2005 02:17 PM |
| Using a large drive on small motor? | murphy625 | General Electronics Discussion | 0 | 03-11-2005 05:23 PM |
| Help! ...no drive movement | CRFultz | General Electronics Discussion | 4 | 01-21-2005 08:30 PM |
| Good DC motor and drive | JRoque | General Electronics Discussion | 11 | 01-02-2005 10:38 PM |
| Belts versus Direct Drive | bsmith | DIY-CNC Router Table Machines | 12 | 06-06-2004 11:09 PM |
