| Composites, Exotic Metals etc Discuss machining Composites, Exotic Metals problems and solutions here. |
Hey guys...... I was milling wood tonight ( a plug for an rc airplane wing) with a .25 2 flute upcut bit, 13000 RPM, cuttin beautiful..... I was inside when I heard something sounding differant and the machine was going but the bit had broken.... Well I looked at my G-Code and I cannot find a problem.... Im just stumped... Any suggestions what to look for ? Would you run the code again or recode the part ? The 'crash' by the way was a shallow cut 1/2" long and about .25 deeper than the rest..... it shouldnt have even broke the bit really - Im stumped....
__________________ Persistance and patience are the key to CNC |
| What kind of wood? Feed speeds? Depth of cut? What brand bit?
| I was milling plywood - about a .35" depth of cut, 13000 RPM, 2 flute bit - made by Porter Cable..... The plywood is the 3/4" 9 ply stuff at home depot - not the cheap stuff - imported 'sand ply' as theyu call it - good stuff,pretty hard... Also - I was running at about 50 IPM, and the step over was 25% (.0625") I have to order a new collet now - it marred my collet some..... so I need to figure out what happened.....
__________________ Persistance and patience are the key to CNC Last edited by ninewgt; 03-30-2005 at 09:20 PM. |
| It looks like the bit came loose in the collet. If it had just snapped it wouldn't have cut deeper. On our router at work I use these: http://www.vortextool.com/standard/p...fm?groupID=264 #1830, If you buy 5 they are $77 for 5. I usually cut around 120ipm @19,000 RPM (for the 1/4" tool), and try to keep the depth of cut to around 1/4" . The 3 flutes cut a little nicer, and they are quieter.
| Well I tacked a piece of foam down (2" styro) and ran the part file - came out fine... so ??? Who knows - maybe some electrical noise, the bit just broke... who knows....... I wish Id have been watching when it ran over the same area - but it cut perfect so no worries
| Stop Bits, Parity | gar | Computers and Networking | 4 | 06-04-2005 02:10 PM |
| Show me the bits | darth442 | General Metalwork Discussion | 0 | 05-18-2005 01:34 AM |
| Mach 1 breaking bits | CNCadmin | Mach Software (ArtSoft software) | 10 | 02-27-2005 08:03 AM |
| Reading 12 bits // encoder - Lead & Lag | dehclau | General Electronics Discussion | 9 | 10-27-2004 02:03 AM |
| i keep on breaking bits??? | joeyboy | General Metal Working Machines | 11 | 03-24-2004 03:18 AM |
