Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Composites, Exotic Metals etc
Composites, Exotic Metals etc Discuss machining Composites, Exotic Metals problems and solutions here.
Old 05-14-2009, 02:34 PM
ninjay is on a distinguished road
CF cloth project
http://img148.imageshack.us/img148/315/cbcase2.jpg
http://img148.imageshack.us/img148/c...jpg/1/w320.png
hey guys. this is my first CF project. i am building arcade sticks out of 8 harness satin CF for my friends and myself. i am aware of all the safety precautions of messing around with CF dust. i will be putting the laminating resin on myself with the molds i made.
my question is... would it be easier to cut the holes out before i laminate or after? also i will be using 24mm and 30 mm hole saws, so do you guys have any suggestions on a good carbide or diamond bits?
Old 05-14-2009, 07:12 PM
composites is on a distinguished road
Its going to be easier for you to drill the holes after you laminate the cf. If your just making a few of these for friends, a standard steel bit will do the job. If your making more than a few of these, then you should probably look into more expensive tooling.
Old 05-15-2009, 06:17 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
I'd drill/cut it while it was still in the green stage (still plastic and not stiff).
You could make a sample piece and try different speed strategies to try out.
Or,you could make a sharp die and punch out the holes while still green. When it hardens you could dress up the edges.
Just a few thoughts = Welcome aboard and have fun.
Cheers - Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
[IMG] code is Off
Textile (cloth) cutting CNC nikolatesla20 General Material Machining Solutions 4 11-09-2010 11:34 AM
Suitable motor for abrasives cloth feeder Syphonics Mechanical Calculations/Engineering Design 1 03-23-2009 08:03 AM
cutting die to cut abrasive cloth? Syphonics General Metal Working Machines 3 11-21-2008 09:15 AM
Need help on DIY Project studysession DIY-CNC Router Table Machines 1 09-03-2006 04:26 PM
rotary cloth cutting tool gevannos Machine Problems, Solutions , Wireless DNC, serial port 2 05-15-2003 05:30 PM
