Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Composites, Exotic Metals etc
Composites, Exotic Metals etc Discuss machining Composites, Exotic Metals problems and solutions here.
Old 01-15-2009, 01:15 PM
xchipx is on a distinguished road
What setup to cut carbon fibre sheet (uk )
Hey all new here, posted a few details about me in the clubhouse
I hope this is the correct thread ! If not mods please feel free to kick my ass.
My brother has a basic cnc machine ( see links below ) that he uses to etch and cut circuit boards. Whether this would be good enough for my app - im not sure yet.
I still need to do a lot of research so i apologise if some questions may be a little " newb-ish "
I plan on working with carbon fibre sheet. Thickness ranging 1mm - 5mm MAX.
I intend for the finished items to be used in a few different applications, perhaps small automotive items , RC and even basic bicycle components.
I understand that cutting CF makes nasty hazardous dust that will need some sort of extraction system to the outside. This should not be a problem.
Did i also read some people are cutting the sheet " wet " to avoid dust and create a cleaner cut?
I dont have a massive budget probably around £1000 -£1500 , this should see me getting a good "hobby standard " machine and other equipment.
Here are just a couple of machines i spotted , any recommendations to these? Or are they no good for my intentions ? The first is the same as my brother uses.
marchandice
and one in the usa that i spotted :
cnc
Any opinions or no good? Need bigger budget?
I appreciate your time reading through my newb post !
-mark
Old 01-15-2009, 04:31 PM
irving2008 is on a distinguished road
see this thread
Dont forget that carbon fibre dust is incredibly evil to lungs so be very sure about ventilation, face masks and get a good vacuum cleaner like a Henry or similar and a suction tube close to the cutter...
Why not come and visit the UK CNC Community
Old 01-15-2009, 09:09 PM
Thanks irving , i will get myself on the uk cnc community site asap !
Also nice one for posting up that link, some great info there especially from mark linder and the others.
Still can you or anyone else give me a few recommendations if the equipment that i linked to would be at all suitable?
Many thanks
-mark
Old 01-16-2009, 04:06 AM
I cant comment on suitablility of machine as I have never worked with CF. I know you will need carbide or diamond cutters to get the best results and since these generally will be small (<3mm dia) a good range of spindle and feed speeds will be necessary, too slow a feed and it'll burn the cutter out from rubbing rather than cutting.
I assume you are just cutting sheet rather than 'milling' as such so a grinding type cutter rather than a fluted one would probably be better. Also some quick googling suggests the cutting forces on CF depend on the direction of the cut relative to the fibre and are similar to those in milling the harder aluminium alloys.
Hope that helps....
Old 01-17-2009, 10:29 PM
Id like to update some info :
Irving, registered on that site mate, ta !
Ive increased budget to £1500 - £2000 if that will help, anyone ?
[IMG] code is Off
CNC filament winder(carbon fibre) wallygator99 Mechanical Calculations/Engineering Design 5 09-02-2007 12:46 PM
looking for a supplier of Carbon Fibre Hard sheet acidcustom Composites, Exotic Metals etc 3 07-22-2007 02:50 AM
cutting 1/4" thick carbon fibre acidcustom Composites, Exotic Metals etc 2 05-24-2007 12:29 AM
Routing Carbon fibre laminate kong Composites, Exotic Metals etc 38 04-08-2007 11:08 PM
quest for knolege, looking for carbon fibre info? Bartman Composites, Exotic Metals etc 5 04-08-2007 10:36 PM
