Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Composites, Exotic Metals etc
Composites, Exotic Metals etc Discuss machining Composites, Exotic Metals problems and solutions here.
Old 12-15-2008, 07:59 PM
tangent is on a distinguished road
epoxy molding problem...
hello...i am having a molding problem that seems to be a tough 1 perhaps some one out there can help me along ...I am casting electrical grade epoxy into a heated steel mold that containes wire leads that must run through the part .. Unfortunately the epoxy upon curing seems to seperat from the smooth surface of the wires causing oil to leak through under pressure when assembled into the transformer...if any of you out there have any possiabl solutions i would greatly appreciate it thanx
Old 12-15-2008, 10:20 PM
Moderator
ckelloug is on a distinguished road
My instinct would be that there is a something vaguely oily on the wires keeping the epoxy from adhering properly. Have you thoroughly degreased the assembly before attempting to pot it?
--Cameron
Epoxy Nerd from the E/G thread
[IMG] code is Off
Adding Metal Powders to Epoxy JerryFlyGuy Composites, Exotic Metals etc 26 06-16-2011 08:54 AM
Greybeard's Epoxy/Aggregate cnc router greybeard DIY-CNC Router Table Machines 40 07-17-2008 04:00 PM
Epoxy/granite machine concept Gizmot Vertical Mill, Lathe Project Log 12 02-28-2008 02:46 PM
Curing epoxy above room temperature Syphonics Composites, Exotic Metals etc 4 05-28-2007 04:11 PM
Quartz filled epoxy... karmicthre DIY-CNC Router Table Machines 9 06-22-2004 08:30 AM
