Results 1 to 6 of 6
Thread: Milling G10 fiberglass, several questions
    Jul 2007
    Hi everyone,
    I got my Taig started doing some parts the other night, and they came out decently:
    http://img206.imageshack.us/img206/866/millingpe4.jpg
    However, the edge quality is pretty poor. I was using a possibly damaged endmill, which might be the problem, and my lazy fixturing solution (four cheap steel plates and two screws) obviously didn't help, so I know to fix those when I need to get serious.
    http://img341.imageshack.us/img341/4...ling001aj1.jpg
    I have searched for info on milling G10, but didn't find any satisfactory answers, so the questions as follows:
    1) How to fix the G10 to some substrate? Should I pre-drill some holes into the G10 and a block of wood/plastic/etc. and screw it down? I have wood, but I don't think it's flat enough to bolt the G10 to. Should I buy a flat plastic block?
    2) What feed rates & cut depth for a 10k rpm spindle and a 1mm diameter endmill? (I need the 1mm endmill because these parts are small.) I've tried 6 IPM and .45mm depth (good edge quality, painfully slow), 12 IPM and .45mm depth (still good), 25-30 IPM and .45mm (terrible, may have killed the endmill) and finally 12 IPM and 1.6mm for the parts shown above. Can I go faster/should I go slower? HSM probably isn't an option on a little Taig cutting G10, I know, but if I can go faster I will gladly appreciate it, I'm a student trying his hand at manufacturing a small run of small RC chassis.
    Thanks in advance!
    Gold Member
    Oct 2005
    Pre-drilling and bolting down will help the G10 stay flat which will help with the finish a little. You can also use double sided tape (the stuff with the foam core) and then use a citrus-type solvent to remove the tape if it sticks too well.
    I'd recommend using fiberglass routers like these: http://www.sgstool.com/catalogs/PDFs...td_RTR_FBG.pdf
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    use sharp carbibe endmills on that stuff ,it is very abrasive and will dull the tool quite rapidly , also watch for delamination , this will tell you that the tools have had it
    Jul 2007
    Thanks for the reply guys; now another question, what if the endmill was running too SLOW a feed rate? What happens? Previously I had forgotten to convert in/min to mm/min so I ended up running at 0.5in/min instead of 6 as the calculations should say (I think).
    I've also bolted down the parts at key points for the next trial so I will probably have some pics over the weekend.
    Feb 2008
    I am also experimenting with machining G10. I am machining with 1/8 and 1/2 inch endmills and using altin coated carbide. The tooling dulls pretty quickly. My past tests on the 1/8 cutter were 100 ipm at 16000 rpm. I would like suggestions on feed rates and spindle speeds as well as any info regarding small diameter center cutting PCD endmills.
    May 2011
    We just got our machine running last week and will be cutting mainly .060 (1.524)thick G10 sheets. I have had very good results with these 10 3 00mm 1181" Chipbreaker Carbide Router Burrs ft Kyocera Tycom | eBay bits, full depth cuts at 35-40ipm spinning at 20,000rpm. Plunge cuts at 25ipm. Very good finish and a great price.
    1. Maho MH600E Milling machine questions???
      By marx911 in forum General Metal Working Machines
      Last Post: 01-23-2009, 01:51 PM
    2. Rhino and milling questions
      By ohno in forum Rhino 3D
      Last Post: 05-31-2007, 11:40 PM
    3. Thread milling problems and questions.
      By magneto259 in forum G-Code Programing
      Last Post: 05-08-2007, 10:25 PM
    4. Newb with thread milling questions using the helix(conversational)
      By metalbytch in forum General Metalwork Discussion
      Last Post: 12-01-2005, 06:30 PM
    5. Questions about milling spindles
      By Hack in forum General Metal Working Machines
      Last Post: 01-27-2005, 05:42 PM
