Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Composites, Exotic Metals etc
Composites, Exotic Metals etc Discuss machining Composites, Exotic Metals problems and solutions here.
Old 08-20-2007, 05:23 AM
Calico is on a distinguished road
Where to find Detail Info of a 3D weaving carbon fiber machine ?
I'm looking for a machine to make a 3D carbon fiber weaving.
I'm looking fot the Info of how to make it !
and I'm looking for that machine, how do they do it ?
the project is how to make a Joint "T" or "V" of say a bicycle made of carbon fiber, of course you have to make the 3D weaving for the fiber.
does anyone has this info for the machine ?
anything ?
cal
Old 08-20-2007, 08:41 AM
chrbau is on a distinguished road
As I understand it so far there's very little weaving going on to make simple things like bicycle frames. You can wrap the T-joint with several layers of carbon. You might want to buy this:
http://goliath.ecnext.com/coms2/summ...99-5505351_ITM
or contact:
http://news.ulster.ac.uk/releases/2006/2124.html
for information on research done on making more complex parts like airplanes.
Old 08-20-2007, 01:01 PM
Jbradym is on a distinguished road
opps! I'll try again. Sorry.
Old 08-20-2007, 01:09 PM
Cal,
For those specific shapes I would think a simple form and vaccuum bag would do. Are you going into production with these parts? Some of the manufacurers will make you custom shapes if the runs are long enough. Check out this guy, I used to work for him and he is a true Composite GOD!
He will know how to help you if anyone can. http://www.swcp.com/~kee/HOME.HTM
good luck
Old 08-21-2007, 04:39 AM
ok, I got the email of the person you called God, I hope he will answer my questions and help.
thank you guys....
looks like this 3D woven thing is very rare to get any info on the net.
cal
Old 08-21-2007, 04:45 AM
oops, I just received the bounce email..
too bad
anyone has any info ?
regards
cal
Old 08-21-2007, 05:42 AM
pointcloud's Avatar
Prototyper
pointcloud is on a distinguished road
A weaving machine will be in the millions of $'s? Would you need miles of cloth per day?
If you just want to make a little, I would suggest a small cotton cloth weaving loom.. Last one I had was $12,000..
You'd be better off buying the finished cloth.. Try here.. www.fiberglast.com
Hey check out my website...www.cravenoriginal.com
Thanks Marc
Old 08-21-2007, 12:00 PM
3DWeaver is on a distinguished road
3D-Weaving
Hello Calico!
I suggest you visit www.biteam.com
Its the only 3D-weaving company. They can produce a variety of profiles, including T and V, using carbon and other fibres.
Good luck.
- 3DWeaver
Old 08-21-2007, 11:44 PM
Thank you 3dWeaver,
actually that's the only site that I find close... but I still can not find how the machine can do that.
Looks like it's a top secret !
anyway... how about creating a joint T or V with the manual way but profesionally ?
I'm thinking of making a Mold system but the carbon fiber will give a smooth, factory quality presult ?
any video/photo/how to do that ?
I saw some DIY photos but the quality is not as good as I'm looking for.
I have CNC machine that can create the Molding for this.
I just need some photo, info specially how you apply the carbon fiber sheet to the T or V joint like factory quality.
for example a bicycle joint, with hollow inside.
I've been searching this with google, youtube, etc, but could not find the detail info I want.
3Dweaver, I believe you can help me with your knowledge (judging by your nick name)
Cal
Old 08-22-2007, 01:25 PM
I could be wrong,
But I think what you are trying to accomplish should be spun on a mandrel.
By "V joint" do you mean an intersection like with tubing? The website I sent you to has pictures of a Carbon Bicycle. That bicycle frame (as I recall) was built as two pieces. The halfs are seamed at centerline. All you need is one layer to establish your shape and subsiquint layers to bond the seams.
I hope that helps?
Its hard to engineer something when you don't know what it is you're engineering
If I am way off I'll shut up..
  #11   Ban this user!
Old 08-22-2007, 10:21 PM
Jbradym,
pls don't "shut up", I need help from the expert.
ok, that bicycle is seemed, what I need is seemless, meaning I need to joint tubing with one go, not half and half.
that's why I though I need the 3D weaving, but it turn out tooooo complex for me, even I have CNC machine to create a mold, but that got to do with the making of 3D weaving.
back again on the bicycle project, they are using 2 molds right ? the cloth is not seemless, because they cut in to half and put it together. right ?
that's what I'm trying to avoid. specially "pipe" joint frame.
my question on this ....
what's is the other way to make the joint tubing with "seemless" ?
cal
  #12   Ban this user!
Old 08-23-2007, 01:07 PM
Calico,
The only other way that I know of, is to do it on mandrels. Your mandrels can be anything (steel tubing, wood dowls, inflateable shapes, or anything) that you can apply release agent to.
let's take the "T Joint " for example.
The steel tubing would be neatly fitted to the shape you want. The vertical leg would be coped to fit the top leg. You can use packing tape or hot glue to secure the mandrels together. Then wrap the shape with layers of tape or cloth untill you have the thickness and coverage you want and then remove the mandrels after it cures.
Removing the mandrels can be tricky, so be sure to use plenty of release agent. I have sucessfully used this technic on several projects. If you use wax as a release agent heat can help in removing the mandrel.
If your shape is more complicated think about using inflatable mandrels. Immagine laying composites over a balloon animal. the mandrel is then deflated and removed or left in place.
Also you can do a sort of investment casting method. this is considerably more time consuming but the results are good. Start with a wax model of the shape you want. cover the model in plaster of paris. Heat and melt out the wax. Lay up your composites. fracture plaster and remove. Obviously you will have to control the thicknesses of the wax model and the plaster so that you finished Part is the finished dimension you want. I know alot of people will think that last one is crazy but Beoing uses a similar technic to make the ventalation ducts for their air planes that way. You could also just use the wax model to lay up on? But the could make a mess in your Autoclave.
Also Cardboard or paper tubes make good mandrels if you don't mind leaving them inside the part.
Does that help some?
[IMG] code is Off
Tools for machining solid carbon (not carbon fiber)-more posted camcutter Composites, Exotic Metals etc 5 04-27-2007 06:23 PM
carbon fiber cncsdr General Metalwork Discussion 3 05-22-2006 11:25 PM
Carbon fiber turmite Composites, Exotic Metals etc 10 08-03-2005 10:20 AM
Carbon fiber CNC Pro CNCzone Club House 0 03-13-2004 04:32 AM
carbon fiber Hobbiest DIY-CNC Router Table Machines 3 01-23-2004 03:40 AM
