Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Composites, Exotic Metals etc
Composites, Exotic Metals etc Discuss machining Composites, Exotic Metals problems and solutions here.
Old 05-23-2007, 03:25 AM
acidcustom is on a distinguished road
cutting 1/4" thick carbon fibre
hey guys
I am looking at using some 1/4" CF hard sheet for parts in paintball markers
Would using flood coolant be OK to use
Also what depth of cuts should I use , I am going to use the following cutters DIAMOND CUT - UPCUT - FC - ROUTERS between 3/32" and 1/8 dia
all help is really appreciated
acidcustom
Old 05-23-2007, 10:41 AM
sbalder is on a distinguished road
I machined some 1/4" cf plate recently for a radio control helicopter I am building. My setup is Dremel Advantage mounted to the quill of a Bridgeport CNC. My skill level is hobbyist and speed wasn't as big a factor as quality. With a 1/16" carbide burr spinning 30K RPM I cut full depth at 10 IPM. I had an air blast nozzle (no liquid) and manually held a shopvac nozzle to help suck the dust.
Old 05-24-2007, 12:29 AM
thanx at least I know I can cut full depth
[IMG] code is Off
CNC filament winder(carbon fibre) wallygator99 Mechanical Calculations/Engineering Design 5 09-02-2007 12:46 PM
Routing Carbon fibre laminate kong Composites, Exotic Metals etc 38 04-08-2007 11:08 PM
quest for knolege, looking for carbon fibre info? Bartman Composites, Exotic Metals etc 5 04-08-2007 10:36 PM
4" thick foam inserts kdoney Employment Opportunity 0 06-12-2006 04:55 AM
Best Mill for 1" thick Aluminum? gtslabs General Metal Working Machines 13 12-31-2003 09:37 PM
