Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Composites, Exotic Metals etc
Composites, Exotic Metals etc Discuss machining Composites, Exotic Metals problems and solutions here.
Old 05-16-2007, 02:08 AM
Syphonics is on a distinguished road
Curing epoxy above room temperature
Currently my epoxy I am using is unable to withstand temperature above 100 degree C. I cure the epoxy at room temperature.
Is it true that the epoxy can withstand higher temperature if it is cure at temperature higher than room temperature.
Old 05-16-2007, 05:02 AM
svenakela is on a distinguished road
Yes. And it will also become a better cure with higher "bonding ratio", the number of molecule chains that hook each other. It will become stronger with much better mechanical properties.
When you use epoxi for room temperature, raise the temperature the first 10-15 hours to 30-35 degrees and then let it cure in 70-90 degrees for a day.
Regards,
Sven
Old 05-16-2007, 05:38 AM
this is the specs sheet of my epoxy.
any idea what temp should the curing be at best.
Old 05-23-2007, 05:00 AM
Lets say 50 degrees Celsius, at least 24 hours.
Also have in mind that if you don't make an exact mixture you will loose mechanical properties too. It says 10:6 by weight, then use EXACTLY that proportion. Not 100 grams to 61 grams or 101 to 59, it should be exactly 100 and 60! Even if I mix up several kilos of resin I go for gram resolution.
And when you mix, make sure to scratch the walls of the cup to get everything mixed. Mixing is the magical keyword to get a perfect cure.
Regards,
Sven
Old 05-28-2007, 04:11 PM
racecomp is on a distinguished road
Post cure the mould with the plug or part still inside at an elevated temperature of at least 60 degC.
Remove the plug or part from the mould and cure slowly to peak temperature higher than you are to be working at by at least 10%.
You should always test thoroughly the products that you are going to use before making the part, check the use by date is OK and follow the data sheet for that product!!! Don't just guess the end result will be a disaster because of lack of product knowledge.....
[IMG] code is Off
Low Temperature Differential Stirling nick.gilling Stirling Engines 148 02-10-2008 01:33 PM
Motor's temperature limits. sotos Syil Products 11 05-15-2007 05:17 PM
Head temperature wildcat Industrial Hobbies (Support forum) 13 12-10-2006 04:33 PM
Using temperature as a fastner pminmo General Metalwork Discussion 11 02-09-2005 03:36 PM
Quartz filled epoxy... karmicthre DIY-CNC Router Table Machines 9 06-22-2004 08:30 AM
