Results 1 to 6 of 6
Thread: quest for knolege, looking for carbon fibre info?
    *Registered User*
    May 2004
    Hello all,
    Iam a stay at home dad and recently, I have an urdge to learn about carbon fibre, I was wondering if there are any good on line books or step to step sites on how to lay up, mold and maybe even machining of said material?
    Any help would be greatly appreaciated , Thanks in advance.
    Bart
    *Registered User*
    May 2004
    Thankyou vary much, looks like I have some reading ahead of me.
    Talk to you soon.
    Bartman
    Jun 2003
    Jan 2006
    If you want to lear the basics get some cheap fiberglass and resin and play with it. MUCH cheaper than carbon fiber and almost as cool, plus it pretty much handles the same as far as layup and molding.
    Matt
    Apr 2007
    This is my first post on this site, my name is Steve and I own RaceComp.
    We make all types of composite parts from high tek parts for the medical industry to decorative show parts for Superbikes. Dont get confused with the different process that are use in the composite industry.
    All our parts are made from pre-preg carbon and autoclave cured under vacuum, high pressure and heat; it is a far cry from dabbing a bit of resin on some dry carbon. The pre-preg set-up is very costly to start with, with elevated temperatures and high pressures that are used in the process, tooling is the biggest issue. A normal fibreglass moult would not last 5 minutes in an Autoclave.
    It truly is an awesome product, the designs and application are endless.
    Have a look at our site; it's a bit out of date now!!! Well overdue for a makeover. www.racecomp.com.au
    Attached Thumbnails Attached Thumbnails quest for knolege, looking for carbon fibre info?-100_1986.jpg   quest for knolege, looking for carbon fibre info?-100_1985.jpg   quest for knolege, looking for carbon fibre info?-triumph-2_low_res.jpg   quest for knolege, looking for carbon fibre info?-racecomp_0349.jpg
    1. CNC filament winder(carbon fibre)
      By wallygator99 in forum Mechanical Calculations/Engineering Design
      Last Post: 09-02-2007, 01:46 PM
    2. Routing Carbon fibre laminate
      By kong in forum Composites, Exotic Metals etc
      Last Post: 04-09-2007, 12:08 AM
    3. steel fibre??????
      By the4thseal in forum General Metalwork Discussion
      Last Post: 12-06-2006, 01:53 PM
    4. Post for Gibbs Quest 51 sp
      By basil1 in forum Post Processor Files
      Last Post: 05-30-2006, 11:07 AM
    5. Beginner's Quest for Advice
      By chantlouder in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 04-07-2005, 12:16 PM
