Results 1 to 6 of 6
Thread: Machining 50mm hole in inconel 625
    Feb 2012
    Uk
    Im in need of some help with manufacturing coursework, so hoping someone might be able to help.
    I want to machine a Ø50mm hole in a short (30mm long) cylinder using a CNC lathe/turning centre.
    I assume the quickest and most efficient way to achieve this is to use a Ø50mm drill head (I have found an insert type drill in the sandvik catalogue that can do this) But im not sure if I need to go up in step sizes? i.e. can I go straight to 50mm, or do i need to go Ø5, Ø20 then Ø50 for example? I cant really find any information on this on the web! What are the advantages/disadvantages of step drilling and would you recommend it for this application?
    Any help would be much appreciated!
    Aug 2008
    Depends on what kind of machine you have.
    I wouldn't even attempt to push a drill that size into inconel with less than a 30hp machine.
    Also, I usually avoid step drilling like the plague.
    Mar 2012
    India
    Smile Inconle 625
    We are using Inconle 625 Material 70 MM Dia * 940 MM Length. Want to do 31 MM I.D in it. Please let me know what is the procedure for it.
    We also have done annealing & rite now the Hardness is 20-21 HRC.
    What type (Grade) of tool it should be used ?
    Thnk's Regard's
    Prasad Kulkarni.
    Registered Khalid's Avatar
    Apr 2006
    Pakistan
    Why not to use simple HSCO drill with that low HRC inconel?
    I will suggest you to do Step drilling , start from Centre Drill, then 8mm drill, then 15mm drill then 20mm drill and so on... We have done a similar job for high temperature Thermowell manufacturing out of Inconel 800H and we have done that hole by Lathe.. For that long you need to precisely Align the Stock on Lathe and drill both side..
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Mar 2012
    India
    Quote Originally Posted by Khalid View Post
    Hey Khalid thnk's for ur quick reply.
    Me trying with the same procedure with 16 MM Drill & Simultaneously modifying with Sandvick carbide drill. Hope that work's on.
    Again Thnk's for your imediate reply.
    Jun 2011
    bavaria
    If you have the tool for it, I think its much better to recess turning axial up to 0,01" of the end of your part, then use a hammer to remove the middle part. If you must do this with a drill bit, than you need a lot of power and a special drill for that material. Generally in stainless Steel an Nickelalloys you should grind your Drill to 130°
    1. Need Help!- Drilling 1.812 hole in 625 inconel
      By wayne623 in forum General Metal Working Machines
      Last Post: 10-25-2011, 03:59 PM
    2. Hole in Inconel
      By rosco in forum General Metalwork Discussion
      Last Post: 08-26-2011, 09:12 AM
    3. Problem- - Machining of Inconel 718
      By Naz78 in forum General Metalwork Discussion
      Last Post: 03-06-2011, 08:51 AM
    4. hole thru .03 thick inconel
      By exnavkj in forum CNC Tooling
      Last Post: 11-26-2009, 08:46 PM
    5. Machining Inconel
      By bigandy in forum Composites, Exotic Metals etc
      Last Post: 03-20-2008, 06:11 PM
