Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Composites, Exotic Metals etc
Composites, Exotic Metals etc Discuss machining Composites, Exotic Metals problems and solutions here.
Old 12-07-2011, 11:08 AM
Zigmaan's Avatar
Zigmaan is on a distinguished road
Post Machining Bondo
I have a project that requires intricate 3d machining and must stand up. The base is wood and will have a pocket about 1/4 deep put in under the logo. I will put in undercuts so that the composite epoxy will stay after, and build up the area about 1/4 above the base material. I have a few questions on this.
I am chossing autobody filler (bondo) because it is cheap.
Questions:
1) Will this material stand up, and if not, what is a good substitute?
2) Will the material cut using H.S.S. cutters? or only carbide?
I might think of more questions as we discuss this topic.
Please visit my website at http://www.avroenterprises.com
Old 12-08-2011, 11:24 AM
Zigmaan's Avatar
Arrow picture of the scroll work to be inserted
I have to finish the model so that the cutter will flow better, instead of dwelling. This will take sonme tim as it is projected onto a cylindrical surface first them built up and tweeked before filleting. I might actuall ask the Fort (historic park) if they will allow me to pull a cast of the original, although, since I have no digitizer....would not make it any easier.
Note that on a 20 inch cannon, this detail is only about 1 x 1.5, and the base material is slowly drying Ash. It is roughed out now, waiting on spring to finish cut it with no logo. I am then intending to pocket the area and insert it. just trying to find the best material.
[IMG] code is Off
Job Opening Machining Fixture Designer w/machining background - MI MachiningJobs Employment Opportunity 0 04-04-2011 04:53 PM
Custom Machining, OEM Machining. peovo-com CNCzone Site News and Contests 0 09-02-2010 04:22 AM
MIS CNC Machining and tooling - General machining - Thermoform Molds modernprecision Employment Opportunity 0 11-23-2007 10:05 PM
using bondo on aluminum surface ? max_imum2000 Casting Metals 14 03-07-2007 07:30 AM
Machining anodized parts or anodize after machining? SRT Mike General Metalwork Discussion 4 03-11-2006 11:22 PM
