Need Help! How to make Carbon fiber sheet ? - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: How to make Carbon fiber sheet ?
  1. #13
    Jan 2011
    Default Re: How to make Carbon fiber sheet ?
    In fact, a vacuum level is very logarithmic.. So a 20 buck pump will give you about nothing.. same a using an air compressor..
    A full high level 2 stage will bring you at -29.7inHg. with a small 1hp Gast, you will get about -27. and a 1/3 .. 1/4 it will be at -21 around.
    You will still be resin rich. Still better than a wet layup, but not the best. Over cnc , for cutting, you will got the same result,.
  2. #14
    Mar 2008
    Make two thin sheets on glass then bond the backs together.
