Problem Surface Coating Curved Mold
Results 1 to 5 of 5
Thread: Surface Coating Curved Mold
    Feb 2013
    Default Surface Coating Curved Mold
    Hello all,
    I'm trying to put a surface coat on a curved mold surface without it sagging, running, or creating vastly different thicknesses of resin. Any advice on technique and/or the proper epoxy/gel coat to use for this application? My parts are out of epoxy, so whatever i use must be compatible. THANKS!
    Jan 2006
    Are you trying to coat the mold or apply a surface layer to the mold which will be bonded to your parts?
    I use Duratec for mold surfaces. For a surface layer on a part, any gel coat laid down with a cup gun at 20-30 mil thickness should pretty well hold its shape and not run or sag.
    You can find everything I mentioned at fibreglast.com
    Matt
    Feb 2013
    ...And those polyester gel coats on fibreglast.com are compatible with epoxy?
    Jan 2006
    Thanks for answering my question...
    The epoxy surface coat I linked to is an epoxy gel coat. You can't use poly or vinyl ester gelcoat with epoxy resin. You've provided almost no information so it's hard to help.
