Composites, Exotic Metals etc
Page 1 of 9 1234 ... LastLast
Threads 1 to 20 of 163
Forum: Composites, Exotic Metals etc
Discuss machining Composites, Exotic Metals problems and solutions here.
  1. Carbon fibre threading improvements?
    Started by k_turner‎, 11-23-2022 04:57 AM
    carbon, de-laminate, fibre, machinist, thread
    03-27-2024, 07:05 PM Go to last post
  2. Lightbulb Processing ceramics
    Started by Dekabus‎, 06-22-2021 05:32 AM
    bottom, hole, pot, problem, week
    06-22-2021, 04:05 PM Go to last post
  3. Book on machining composites / carbon fiber?
    Started by skyways-uav‎, 11-25-2020 06:24 PM
    book, carbon, composites, fiber, machining
    04-24-2021, 02:33 AM Go to last post
  4. Question Woodcarving cnc Feeds And Speeds
    Started by grabadosjapansa‎, 07-10-2005 05:25 PM
    01-25-2021, 02:10 PM Go to last post
  5. How do I cut Water Epoxy?
    Started by jaru-eri‎, 08-02-2019 10:09 PM
    advisable, epoxy, mill, purpose, speed
    10-13-2020, 07:27 AM Go to last post
  6. CNC trimming Kevlar
    Started by AndyMcB‎, 12-31-2017 05:55 PM
    cnc, trim, parts, kevlar, year
    05-25-2018, 10:38 PM Go to last post
  7. Milling Carbon fiber Sheets - Need Help
    Started by lopata‎, 03-22-2018 07:14 AM
    coolant, cutting, dust, problem, water
    05-25-2018, 10:11 PM Go to last post
  8. G10 tooling
    Started by Frankjs‎, 03-30-2018 10:48 AM
    abrasive, end, g10, mills, test
    05-25-2018, 10:01 PM Go to last post
  9. Need Help!- How to make Carbon fiber sheet ?
    Started by Calico‎, 06-22-2016 09:24 PM
    carbon, fiber, free, make, sheet
    10-27-2017, 07:00 PM Go to last post
  10. Newbie- Is it possible to mill carbon fiber or G10 at slow speeds?
    Started by steveo290‎, 08-24-2015 11:03 PM
    cnc, forum, g10, machine, mill
    10-27-2017, 06:49 PM Go to last post
  11. Need Help!- Deep indented mark at start point of carbon fiber
    Started by storage‎, 08-21-2017 08:46 AM
    10-27-2017, 06:39 PM Go to last post
  12. LOOKING FOR TRESPA CUTTING BIT
    Started by jramos187‎, 10-24-2017 11:58 AM
    000, bit, rpm, sheet, trespa
    10-24-2017, 11:58 AM Go to last post
  13. Need Help!- Where to find HDF ?. Looking for HIGH DENSITY FIBERBOARD 3/4" or 20MM
    Started by jxdxwx‎, 12-14-2015 05:06 PM
    cnc, hdf, mdf, spoilboard, vacuum
    10-23-2017, 03:00 PM Go to last post
  14. Need Help!- Corecell GURIT S1800
    Started by waterrat‎, 05-05-2017 01:16 PM
    chamfer, cnc, gurit, material, s1800
    05-05-2017, 01:16 PM Go to last post
  15. Need Help!- Heavyweight / metal-alloy plastics
    Started by DylanRose‎, 02-16-2017 03:03 PM
    02-16-2017, 03:03 PM Go to last post
  16. Need Help!- What setup to cut carbon fibre sheet (uk )
    Started by xchipx‎, 01-15-2009 02:15 PM
    not
    01-06-2017, 08:21 AM Go to last post
  17. Newbie- Cutting Carbon Fiberon a 3 axis CNC
    Started by Savich‎, 01-08-2014 09:44 AM
    everyone
    12-21-2016, 05:02 PM Go to last post
  18. Need Help!- Bonding Corian to Corian. What to use?
    Started by mcphill‎, 01-18-2013 12:48 PM
    available, indicate, then
    08-16-2016, 03:54 AM Go to last post
  19. machining graphite
    Started by davidsutton‎, 01-16-2008 09:35 AM
    2 Pages
    1 2
    08-10-2016, 11:57 AM Go to last post
  20. outdoor plastic material help!
    Started by jdhutch82‎, 06-08-2016 12:04 PM
    coat, make, material, plastic, wanna
    06-08-2016, 08:03 PM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 4 users browsing this forum. (0 members & 4 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
