- acramatic 2100 bios help?!?!
i have a Cincinnati milacron lancer with a2100, the battery on the real time cpu board was changed without any power to it, so on reboot i got the rt fail and other fails, i tryed to use the vga card and keyboard and power supply on the rt board to change the setting like people talk about on here but cant seem to figure out how exxactly im suppose to fix it and or if i need anything els if anyone has any info to help me id really appreciate it.reply or pm me or email jerrybmiller3@gmail.com
Re: acramatic 2100 bios help?!?!
There is no need to post your question twice. You may bump your question, but creating multiple posts for the same question does not help you getting an answer, it tends to sway people away from helping. You need to contact FIVES, they will get you the BIOS settings you need for your exact machine. Once you get the correct setting in the RT board, it should hopefully solve your issue. Below is the contact page for them. They are for better words, the machine builders. If there is ANYTHING you need to know, they can help. You also need to supply more information on your machine as well when you contact them. They will need to know the model, the serial number, drawing numbers, etc.
FIVES
Hi dear.
I have a Cincinnati Milling Machine. With Acramatic 2100 control. I had a bios battery message. And the clock was constantly erased. I changed the battery on the ws board. Unfortunately, I have ws fail alarms. And does not work.
This ws board model is: aa 670917-310
Do you have bios settings?
please guide me .
my mail : amir.mmhb@gmail.com
- You may not post replies
- You may not edit your posts
Forum Rules
