Page 55 of 102 FirstFirst ... 5455253545556575865 ... LastLast
Results 649 to 660 of 1224
Like Tree1Likes
Thread: Hoss's 3D Printers
  1. #649
    Registered FannBlade's Avatar
    Jun 2011
    My 3D rendering.
    My CNC build: http://www.cnczone.com/forums/genera...ml#post1059321
    C-Constant
    N-Nonworking
    C-Contraption
  2. #650
    Mar 2011
    Looks Racey
    My CRP 48 x 48 build [URL="http://www.cnczone.com/forums/open_source_cnc_machine_designs/144173-crp_4x4.html"] CRP 4x4[/URL]
  3. #651
    Feb 2007
    PID Controller for Hot End
    Hi Hoss,
    would these PID controllers work for the hot end?They seem like a really good deal.
    Buy.com
    Rob
  4. #652
    Gold Member hoss2006's Avatar
    Apr 2006
    Quote Originally Posted by rwestbr View Post
    Hi Hoss,
    Buy.com
    Rob
    Man those are cheap, worth a try at those prices.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  • #653
    Registered LeeWay's Avatar
    Jun 2004
    I have one like it that I just started using for the heat bed.
    Works great for that, but you will also need a thermocouple and an SSR.
    My thermocouple was only about $7 off Amazon.
    I paid $40 for the SSR, but Ebay carries them a lot cheaper. Mine came from Automation Direct.
    Lee
  • #654
    Apr 2006
    Next project for the Prusa, a mini router engraver attachment.
    I have to finish making this new better X carriage first, should be more stable than the 3 bearing unit I'm using now.
    Reinforced Prusa X Carriage with Slim LM8UU Holder by jonaskuehling - Thingiverse
    Thought I got the rotary tool at Harbor Freight but don't really remember.
    Hoss
    http://www.youtube.com/watch?v=k1a7XnnSI4E&list=UUjoRKEpk7uE5Wzf4b-IFTFg&index=1&feature=plcp]Reprap Prusa Mini Router Engraver - YouTube
    Attached Thumbnails Attached Thumbnails Hoss's 3D Printers-101_0513_cropped_452x600.jpg   Hoss's 3D Printers-101_0516_cropped_512x600.jpg   Hoss's 3D Printers-101_0517_cropped_499x600.jpg
  • #655
    Feb 2007
    Hi LEE
    Quote Originally Posted by LeeWay View Post
    Hi LEE,
    Please look at these features for me and tell me if the SSR is inclusive to this unit or just controls voltage to an SSR.
    Buy.com - Dual Digital F/C Display SSR PID Temperature Controller With 2 Built-in Alarm
    DUMB QUESTION : after looking on Ebay I have my answer
    Rob
  • #656
    Jul 2003
    Dam Hoss you get better every day!!!! What's next?
    Bob Adams
    CNC Programming Software Tools
  • #657
    Jun 2004
    No. The picture is of the one that I have made by Mypin.
    For that model, it needs a model number that starts like TA4E to be able to use the lower voltage to run this. Without the E, you have to connect it to 110 volts or anything from 80 to 260 AC or DC.
    It does come with one little relay inside, but that is only an alarm relay. It's fairly small.
    It only controls the control voltage for an SSR. My SSR is nearly as big as this Temp control. The control voltage to operate the SSR is like 3 to 32 VDC.
    I run my heated bed on 12 VDC @ 15 amps, so my SSR can run something 3 to 200 VDC @ 25 amps. Plenty overkill.
    There are better places to get these from than Buy.com I think.
    I'll add a few links shortly.
    "http://www.amazon.com/Digital-Display-Temperature-Controller-Alarms/dp/B005NGL4KG/ref=pd_sbs_indust_6"]Amazon.com: Dual Digital Display PID Temperature Controller SSR(2 Alarms): Electronics
    This is the thermocouple I bought to use with the heat bed.
    "http://www.amazon.com/Thermocouple-Sensor-Probe-Temperature-Controller/dp/B005G14R70/ref=pd_cp_e_1"]Amazon.com: 90cm Thermocouple Sensor Probe for Temperature Controller: Home Improvement
    Not sure what you would use for the hot end though.
    Lee
  • #658
    Feb 2007
    Thank You LeeWay!!!!!
    Rob
  • #659
    Apr 2006
    Quote Originally Posted by Bob Adams View Post
    Bob Adams
    Thanks Bob, when are you gonna build one, they are a lot of fun.
    Hoss
  • #660
    Jul 2003
    Quote Originally Posted by hoss2006 View Post
    Hoss
    I wished you started the SeeMeCnc first, I bought the parts one like you got, so I could follow along with you. I'm not knocking down SeeMeCnc it a good kit. You are doing a great job and having fun to boot. I may get the Prusa Mendle yet. So i put it on the back burner. I'm like you have to many projects. It looks like this thread can go on for along time, with all the changes you come up with to your printer. Looking forward to see some Milling and Engraving Vids on your printer, I like the bearing setup your printing.
    Cheers
    Bob
  • Page 55 of 102 FirstFirst ... 5455253545556575865 ... LastLast
    LinkBacks (?)
    1. Hoss's G0704
      By hoss2006 in forum Benchtop Machines
      Last Post: Yesterday, 03:27 PM
    2. Hoss's ZX45
      Last Post: 09-06-2012, 10:23 AM
    3. 3D printers
      By Metzindustries in forum Suggestions for the CNCzone.com site.
      Last Post: 09-01-2011, 10:02 AM
    4. Hoss's G0704
      Last Post: 09-10-2010, 02:40 AM
    Visitors found this page by searching for:
    Nobody landed on this page from a search engine, yet!
    SEO Blog
