Results 1 to 11 of 11
Thread: Problem with DSP controller RZNC 0501
    Oct 2008
    I have just got my CNC router working really well with V-Carve Pro at school, now all of a sudden the DSP controller (RZNC 0501) is playing up. When I plug in I get a message which quickly flashes on the screen - "Is boot loading .......... please wait", but nothing happens. I feel I may have accidentally re formatted the system or something. Does anyone have any ideas what I can do to fix the problem? Using the DSP controller with USB stick is perfect for me because students can do all of the prep work and just give me their USB stick when ready to do the machining. Hence, I don't really want to go to a breakout board and Mach 3. for example. Any help would be very much appreciated
    Registered rocabig's Avatar
    Dec 2005
    when this hapenede to me ronny from exertec sent me this it worked for me
    1.please find the PC to DSP black cable , before you connect dsp to pc, please pressing the green "ORIGIN/OK" button all the time, then connect the dsp to pc, means, give power to dsp, 5 seconds later, release your finger, means, don't press it. then you'll see "Start modes: Normal start and Emgentcy progr", please choose the "Emgentcy progr" to format the dsp controller. then adjust the correct parameters and try to use the dsp , see if it works well.
    2.When it says "not enough memory to run file please delete some files", means , you have copied so many files to dsp controller, please remove some of the files that you don't use, you can remove from menu--advanced pro setup--file maintennce--delete file. then try to use the dsp , see if it works well.
    3.If the above solutions can not solve your problem, please "reinstall the dsp program ZHBUSB"
    Richard
    Oct 2008
    Talking You're a magician Richard
    Richard, I just watched Melbourne Victory thrash Gold Coast 4-0 and I thought that was fantastic, but this advice you gave me has surpassed even that satisfaction. IT WORKED!! Thank you very much, I (and my students) are for ever in your debt.
    Dec 2005
    Not a problem
    been throught that before know how anoying it can be
    when your machine wont work.
    Richard
    Registered kram242's Avatar
    Mar 2005
    Blog Entries
    1
    What if we updated the logo and now we get a blank screen?
    It seems nothing works
    Thank you in advance
    Mark
    Mar 2010
    Turkey
    I have RZNC-06 type laser cutting machine, the DSP unit does not control to machine. Because the display not stability Allways move like push the buttons change the menus itself, I upload the file from pc there is no problem. But I don't use the machine from DSP.
    Help me please
    Aug 2010
    Albania
    RZNC-0501 NOT RECOGNIZED
    hello masters!
    i have a problem with a new "rznc-0501". i connected the usb and installed the "usbcam.inf". the driver ok, but when I try to open "ZHBUSBConnect_E.exe" it shows me a message:
    "Can not identify USB communication protocol, please contact dealer and employ latest version!"
    then after pressing "OK" i get another message:
    "Failed to create empty document"
    and it doesnt open the program, what can i do??
    CAN YOU HELP ME PLEASE?
    Best regards
    Andi Demiraj
    Sep 2008
    United Arab Emirates
    @Richard, I know its been a while since ur post but.......Thanks for Sharing......Its a life saver.
    @Andi, I was getting the same message, It may seem odd but I found out that after removing my antivirus program it works well.
    Best regards,
    Mehtab
    Jan 2010
    Richard... I'm have the same blank screen/DSP 0501 problem you described... ready to go to Mach 3 and new boards because your Roctech "fix" didn't work for my pendant. Have you had a problem since? Is there anything you can suggest before I return the pendant to the Chinese router manufacturer? It's a brand new machine. Thanks! Austin
    lazybear@alum.mit.edu
    lazybear
    Jun 2011
    pakistan
    HELLO EVERY BODY.
    THIS IS ASIM FROM PAKISTAN.
    WE ARE MANUFACTURING CNC ROUTERS, WITH WORKING AREA 1525mm X 3700mm.
    ANY POSITIVE INPUT / SUGGESTION WILL BE APPRECIATED.
    REGARDS
    Dec 2012
    Italia
    aiuto inavvertitamente ho formattato in parte il mio RZNC 0501 COME POSSO FARA PER RIPRISTINARLO
    1. RZNC-501 host program
      By arzie2000 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 11-08-2012, 02:15 AM
    2. RZNC-D5416 (zhb275) controller problem
      By coco.han in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 08-20-2009, 08:36 AM
    3. EP controller problem
      By uwphenke in forum Engraving Machines
      Last Post: 02-10-2009, 12:32 PM
    4. cnc controller problem
      By shadybacon in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 10-11-2006, 09:07 AM
