Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 10-28-2009, 09:44 AM
Travisty is on a distinguished road
Routech 250 Twin Table problem
Hey guys. I've been working with this CNC for a couple months now and am just getting started with the post for my right table on the CNC. I set up pop ups and an origin to mimic the left tables setup (for ease) and threw a program that I have working on the left table to the right... Well, all the values seem to be correct, except I keep getting an error.
My right table moves with V instead of the Y the left table uses. My gantry and table moves to the first section of code and executes with no problems, see example below:
G00 X9.1052 V10.2072
M71 M110
Z.5
Z.35
G01 Z0. F100.
X9.8791 V13.103 F600.
After it finishes that section, it gets this line:
G03 X9.3183 V13.726 R.5
And throws the error code NC101, sighting one Process, with an explanation of Positive Software Overlimit Travel in Y.
Why would it say I'm getting an overlimit in my Y?! I guess what really has me stumped is that it executes fine on my left table and it has no problem executing the first line on the right... I can't figure it out at all.
Any help? Any more examples needed? Anything I'm simply overlooking?
Old 10-28-2009, 01:40 PM
More information for hopefully a more speedy response:
The tables slave together fine and will run the full program with no issue. I can move the right table around to any position and it won't throw the overtravel error.
I've tried multiple G30x (x representing 0-3) codes, all with mixed results. The most odd result I had was with using G302 on my post with V-values. It moved the left (Y) table for almost all of the movements, except when it hit a large 12"-Radius, where it stopped moving the left table and moved the right, then immediately stopped the right and started the left again.
Almost all of the moves prior to that are G02's and G03's, so the thought that maybe only radii moves-move the right table isn't accurate.
There were no Y's in my program other than DLY for a delay.
SCM Routech 240 , 2001 / EnRoute Zilog StairguyMark CNC Machining Centers 1 12-14-2009 09:37 PM
Newbie- Routech Chronos with NUM controller manuals indybiker CNC Machining Centers 0 06-30-2009 08:01 AM
Best software to make stairs with Routech 2001 240 StairguyMark Canadian Club House 0 04-09-2009 06:59 PM
Routech vises and clamps alternatives. thinkingcnc WoodWorking 1 03-20-2009 10:27 PM
Conversion to programable independant heads for Gantry Twin head router table ohallock DIY-CNC Router Table Machines 0 04-18-2006 07:20 PM
