Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 03-17-2005, 10:34 PM
JAGYZF is on a distinguished road
Setting Tool Height
We have a large older Komo router with 4 main heads, attached to the 4 mains are 8 auxiliary routers. We are looking for a faster way of matching tools from 1 router to the next due to we run multiple parts at 1 time. Currently we place the tools in the 4 routers on the right end of the machine. Lower those units down 1 at a time to touch off the part they will be machining. Then tighten the tool in the corresponding router on the left end by touching the left part. This is very time consuming. Is there an adjustable gauge that could be used to match tools up at the machine? Or does anyone have another idea as to how to match tools up w/out touching off the parts? The 4 mains are BT-30’s so we can set the tools up off line.
Old 03-18-2005, 07:06 AM
ger21's Avatar
Can't you just use a block to set them all the same?
Old 03-21-2005, 05:09 PM
One block would not work due to the variety of tooling used in these heads. We used dovetail, 1/16” – ½” bits, along with differnt types of boring bits & countersinks. Some tools are out of the collet ½” some of the boring bits are out 4”. This is why we are looking for an adjustable tool.
Old 03-21-2005, 06:11 PM
buscht's Avatar
buscht is on a distinguished road
Are you talking about a tool presetter?
http://www.auto-met.com/fowler/minipre.html
This ones about $7900
Old 03-21-2005, 06:30 PM
We do have a tool presetter. As far as I know it only works with tools that the whole tool holder detaches from the motor, Ex. HSK, BT-30’s & 40’s, etc. We do use the presetter on our 4 main spindles this machine has, due to they are BT-30’s. These small auxiliary routers do not have detachable tool holders; the collet cup is right on the end of the spindle. What I am trying to find is something to set tools in routers that we must placed the tool and collet in at the machine. Or at the very least match the tools from one router to the next. Router 5 & 9, will have the same tools, 6 & 10 will have matching tools, etc. When the tools are installed by hand this makes it impossible to match the tools without touching them to something.
I was hopeing to find something similar to a presetter, but with a magnetic base that would attach to the motor and allow us to set the tools.
Old 03-22-2005, 08:22 AM
buscht's Avatar
There are several threads in this forum that talk about ways to touch off the bits using a switch or ground contact.
Here's one
Tool setting probe
Do a forum search for 'set Z height'
Tool height "touch off" tool unusable DHK DeskCNC Controller Board 6 05-06-2006 01:54 PM
Tool length sensing! Swede FlashCut CNC 15 10-12-2005 08:51 PM
Setting Work & Tool offsets Shizzlemah Fadal 7 04-16-2005 01:04 PM
Tool setting probe JFettig Mach Software (ArtSoft software) 18 03-12-2005 08:33 AM
Tool Height Offsets JamesBond Machine Problems, Solutions , Wireless DNC, serial port 6 06-01-2003 03:01 PM
