Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 08-28-2009, 05:02 AM
alansmith is on a distinguished road
Wink CNC Controller board
Hi everyone!
I need help in finding a controller board for my drivers to my cnc machine.
Originally it is a China machine with an PCI controller(Chinese) (3 axis) and i want to change controller to make it more compatible with other software.
Here is descriptions of Driver inside(see attached file).
I want a board operated trough paralell port.
Any suggests?
Old 08-28-2009, 06:17 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Alansmith,
Lots of companies make breakout boards that interface to a parallel port that will work with your drivers, see the links below.
http://www.cnc4pc.com/Store/osc/prod...roducts_id=161
http://campbelldesigns.net/breakout-board.php
http://www.pmdx.com/PMDX-122
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 08-28-2009, 07:55 AM
cabnet636 is on a distinguished road
look at wincnc or mach 3
http://www.wincnc.net/
jim
James McGrew camaster x3, aspire software
www.mcgrewwoodwork.com
Old 08-28-2009, 09:39 PM
KOC62's Avatar
KOC62 is on a distinguished road
Smile
alansmith,
Are you saying that you have the drivers as shown in the attachment? It doesn't look like a pci card to me.
The driver in the attachment doesn't need a controller board since it already has an opto-isolator and can be connected to a parallel port. The actual pins used on the parallel port is dictated by the software used. For example, Mach3 has a certain pinout given in their installation manual. Mach3 provides a pinout for STEP and DIRECTION for each axis used, which I interpret is the PULSE and DIRECTION on your driver.
Old 08-30-2009, 07:28 PM
Torchhead is on a distinguished road
Originally Posted by KOC62 View Post
alansmith,
The Motor Drives are very similar to other opto input Step & Dir drives. The opto needs +5 as the source (common) just like the older Gecko 201. Trying to sink the 10 to 15 ma with a raw parallel port is a stretch. With most on-board ports running at 3.3V the connection to a source with a 5V pullup could cause port problems on the PC. You will have to supply the 5V from an external source or steal it from the PC power supply.
A breakout serves to easily access the port signals and should sink or source sufficient current. Just as important a good BOB will provide:
Opto isolated inputs
Input connection terminals
Signal buffering and conditioning for better noise immunity
Indicators to help with troubleshooting
High current outputs for driving external Relays
Power to drive the optos (+5 regulated)
Power to drive the relays (+12 to +24 VDC)
Separate "floating Power" to drive the opto input
Plug-n-go support for MACH3
Some of the more advanced BOB's also offer
Expanded Inputs (more inputs from one parallel port)
Expanded Outputs to drive more Relays (more outputs from one parallel port)
Integrated power relays for AC or DC loads
Future expansion options. (plug-in Spindle Speed, more relays and DTHC)
Option for Step & Dir monitor (Pulse Sniffer)
Options for controller layout using a modular card approach.
Small, easy to mount compact size
Complete, concise user manuals
One button install/Auto-load of MACH setup (profiles, screens, plug-ins)
Support for EMC2 (drivers, setup and help)
Custom Cases/enclosures/mounting plates
Active On-line support forum
Phone support
Extended Warranty
TOM Caudle
www.CandCNC.com
www.CandCNC.com/UBOB.htm
non-proprietry controller board? draughted Carken Products (Deskam, DeskCNC etc) 2 04-04-2008 01:48 PM
SM-1 controller board ID tjs88yj HURCO 0 03-30-2008 02:18 AM
Help need Maxnc 10 OL controller board magneto259 Want To Buy...Need help! 15 03-10-2008 04:22 PM
Connecting a Controller Board kpkale Carken Products (Deskam, DeskCNC etc) 7 07-29-2007 10:16 AM
One controller board does it all? Hack General Electronics Discussion 4 03-07-2006 04:51 AM
