| Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here! |
I'm thinking about setting up a system of manufacturing that would require CNC routering some wood pieces. I know CNC isn't ideal for trying to pump out quantity but it may be the only option. I was hoping to get some input on what are the cheap decent CNC wood routers. I only need a very small bed - Y movement 3", X movement 7", Z movement 2" And links and ideas would be great! Everyone always seems to talk to me about techno, is that my best option? I've worked a lot on shopbots but I figure they aren't exactly what I want for this. K2CNC seems interesting especially the KTM-0704 which seems to be a tiny little vertical mill. I'd need to buy a bunch of them and line em all up to pump out parts to price is a big concern. Thank you for the help! Also I might be willing to build my own… anyone have any links to peoples DIY websites? I just got access to a Tormach that I want to start playing with anyways. |
| Here is a good thread on cheap CNC's the size you want. http://cnczone.com/forums/showthread...light=fireball |
| A larger machine would let you load multiple parts, and would save time on loading and unloading. Time is money.
| All of these small machines seem to be geared towards PCB board making and other low machine stress projects. I want to do fancy wood work. Think stuff like cutting topography out of a solid chunk of hard wood. Are there any different considerations that I should take into account for this application when looking at these little machines? |
| If you really want a small machine, you might want to look at this one. It's capable of higher speeds than most others I've seen. http://www.romaxxcnc.com/products.htm
| camaster builds a mean little industrial machine known as the mc class, there is one on display at mann tool in columbia sc. jim
__________________ James McGrew camaster x3, aspire software www.mcgrewwoodwork.com |
| The most important item you left out is price - what's your budget? Also, how willing are you to learn. If you don't know CAM or CNC yet, you have a long road ahead. The Fireball is a quite capable machine, but not the stoutest. It will do VERY fine work, though. I have a bunch of stuff I have done on mine posted here: http://public.fotki.com/mcphill/mcpi-inc/fireball/ It will indeed route hardwood (with the upgraded Bosch Colt spindle, not with a Dremel) with no issue, this is my first real 3D machining, in Oak: http://public.fotki.com/mcphill/mcpi...e-hammer-form/ Mind you, the machine is more capable than me at the moment. I usually make a few mistakes in setup and adjustment as I make my parts. This is just a "learning platform" for me right now, as ALL the skills I am learning will be directly transferable to a large mill and milling metals (or any other material). I just wanted to start at a lower cost entry point so that I could make sure I could get from point A to B like I thought I could (I have now done so), and without breaking the bank. In the process, I have learned TONS about CNC, CAM, Scanning, Reverse Engineering, etc. |
#10
| I would go with a larger machine (like ger21 said), load more parts per cycle, instead of running a single part (unless you really enjoy standing at a machine all day).
__________________ Free DXF Files - Vectorink.com - myDXF.blogspot.com |
#11
| I know Solidworks well and I use SolidCam in that. Also messed with other cheap CAM software. Pretty well versed with the shopbot and its proprietary software. Hopefully I can get up and running with something fast... It seems like there's two groups the 500-1000 group and the 2000+ group. What really are the advantages of the 2000+ range? Theoretically I should be able to do what I want with any of these systems right? The MDF on the fireball scares me... |
#12
Ya I see what you're saying that probably makes more sense. But I still want to at least start with a small little guy and go from there. |
| recommendation for a small pcb mill | Aurbo | Open Source CNC Machine Designs | 1 | 01-26-2009 03:37 PM |
| Wood Routers in Jacksonville, Fla. | ajh359 | Mentors & Apprentice Locator | 3 | 11-17-2008 02:39 PM |
| Using wood routers on CNC | DrStein99 | CNC Tooling | 1 | 09-05-2007 09:44 PM |
| Any Controlller recommendation for a 4'x4' wood router? | journeyonline | Stepper Motors and Drives | 14 | 01-22-2007 07:08 PM |
| damn wood routers | sdwilson | Mastercam | 3 | 08-15-2003 10:15 AM |
