Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
  #13   Ban this user!
Old 08-02-2009, 09:49 PM
mcphill is on a distinguished road
Originally Posted by anchange View Post
It seems like there's two groups the 500-1000 group and the 2000+ group. What really are the advantages of the 2000+ range? Theoretically I should be able to do what I want with any of these systems right?
I would "hope" the 2000+ range would yield a stouter machine. You won't need a really high HP spindle, the Bosch Colt will more than likely do anything you have described so far. If you can swing a nice all aluminum frame, with a decent Z height, you should be all set. I can't recommend anything specific, as I haven't been looking for them. My next step from the Fireball will be either a used Knee Mill that I will CNC myself, or a Tormach, or something like that. I am also looking in to a huge ground up servo powered "router" - like 6' x 6' x 3-4' - to machine some large blocks of foam. The blocks will be a pattern for making some larger pieces ; )
recommendation for a small pcb mill Aurbo Open Source CNC Machine Designs 1 01-26-2009 02:37 PM
Wood Routers in Jacksonville, Fla. ajh359 Mentors & Apprentice Locator 3 11-17-2008 01:39 PM
Using wood routers on CNC DrStein99 CNC Tooling 1 09-05-2007 08:44 PM
Any Controlller recommendation for a 4'x4' wood router? journeyonline Stepper Motors and Drives 14 01-22-2007 06:08 PM
damn wood routers sdwilson Mastercam 3 08-15-2003 09:15 AM
