Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 07-20-2009, 07:21 AM
gerry2112 is on a distinguished road
Optomizing Vacuum Table hold down pressure
Hi
I am interested in maximizing vacuum table holdown force. I currently have a 48" x 96" wooden plate with typical square pattern cut into it. I then usually top it with a 1/2" MDF sheet with outer edge "O" ring. I have 4 intakes at the front of the table to the 10hp "Travaini" vacuum pump. I find the rear end of the table does not hold as good as the front. Are there better ways to hold down material?
Thanks, Gerry
Old 07-20-2009, 07:38 AM
ger21's Avatar
Can you move the inlets toward the center? And make sure you seal the MDF, especially the edges.
Old 07-20-2009, 08:20 AM
Smile Vacuum table hold down
Is it common to add 4 more intakes at the other end of the table?
Would this help the situation?
Thanks.
Old 10-06-2009, 06:00 PM
John J MURPHY is on a distinguished road
You are losing vacuum through the MDF
John Murphy
Need vacuum hold down solution originator Work Fixtures and Hold-Down Solutions 3 06-17-2009 08:38 PM
pressure hold problem plz help fsa Mechanical Calculations/Engineering Design 1 08-20-2008 09:29 PM
hold pressure on????? fsa Mechanical Calculations/Engineering Design 0 08-14-2008 04:15 PM
Need Help!- Vacuum Pump Pressure mbessant Work Fixtures and Hold-Down Solutions 3 07-10-2008 03:15 AM
4x8 Vacuum Hold Down elogicca DIY-CNC Router Table Machines 3 07-23-2007 09:06 PM
