Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 07-09-2009, 11:51 AM
benjulian is on a distinguished road
4Axis question for Jeff
Hi Jeff-
Over the next month, I'm going to reassemble a used 3 axis machine I purchased secondhand and get it up and running. It is a large, 5 X 10' extruded Alum. router table with a 5hp HSD spindle.
I'm going to add a 4th axis, a rotary indexer, in order to produce asymmetrical sculptures (just high density foam). (Think custom wine bottle designs to start, maybe lifesize human figures in a year!?). I have been in contact with Robert Grzesek from MeshCam. He recommended that I talk to you regarding routing using a 4th axis rotary table.
I have heard that it was possible to unwrap a model- just heard that it might distort the math a little (I'm guessing that the more cutter paths you create for one model, the more accurate it would be ?). Did you experience this problem?
Alias will generate STLs no problem. I will have to figure out if it has the capability to unwrap a model. I don't use Rhino.
Thanks for your time Jeff,
Ben Julian
Old 07-09-2009, 12:45 PM
ger21's Avatar
Not sure why you want to unwrap it?
Anyway, I don't believe the Jeff you're looking for posts here. Try the MeshCAM forum, he'll get back to you very quickly there.
http://www.grzsoftware.com/forum/
Old 07-09-2009, 08:29 PM
cabnet636 is on a distinguished road
i am almost there!!
jim
ID:	84156   Click image for larger version
Name:	Fullscreen capture 792009 92503 PM.jpg‎
ID:	84157   Click image for larger version
Name:	Fullscreen capture 6202009 81840 AM.jpg‎
ID:	84158   Click image for larger version
Name:	Fullscreen capture 792009 92327 PM.jpg‎
James McGrew camaster x3, aspire software
www.mcgrewwoodwork.com
X4+ 4axis Martin Long Syil Products 3 08-26-2008 03:45 AM
Looking for Jeff Davis CuttersCov CNCzone Club House 4 08-09-2006 08:49 PM
L297-8 and 4axis BOB aem_argentina Open Source Controller Boards 1 02-20-2006 09:55 AM
Help contacting Jeff or finding new controller lancedulak Xylotex 2 05-13-2004 09:17 PM
