Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 07-02-2009, 04:43 PM
joeyg is on a distinguished road
Question Bearing Failure on SUDA SD1208
We bought this one here SUDA SD 1208 CNC router.
http://img145.imageshack.us/my.php?image=img0227yp6.jpg
We have been using it to cut aluminium sheets, 5mm thick.
Yesterday the spindle motor of that machine became noisy.
We have been using it for about 40 hours in total, since last November.
We have been careful in warming it up all the times before beginning cutting.
We took apart the spindle motor and found out that the roller bearings needed to be replaced.
As of right now we do not know yet if we will be capable to re-assemble it back.
Anybody had similar problems?
Are this spindles standardized? In that case we would consider buying a more robust one. 40 hrs is kind of short for the life of some bearings.
Any feedback appreciated.
Thanks.
Need Help!- SUDA SL4030 LASER ENGRAVER SHARE EXPIRIENCE ANDREAS1968 Laser Engraving & Cutting Machines 0 03-02-2009 05:39 AM
Need Help!- Cooling liquid for SUDA SD1208? joeyg Commercial CNC Wood Routers 4 12-29-2008 06:56 AM
Bearing failure question bob1112 Mechanical Calculations/Engineering Design 6 11-14-2008 06:56 PM
Tapered roller bearing vs. angular contact bearing boyvox Linear and Rotary Motion 12 01-25-2007 02:49 PM
Bearing Failure Mr.Chips DIY-CNC Router Table Machines 5 11-15-2003 10:03 AM
