Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 05-26-2009, 03:39 AM
wilrod is on a distinguished road
ROUTER MAKES STEPPER MOVE
Hello everyone. We have a Multicam Series I router at work and am upgrading to Mach 3. I am familiar with Mach 3 and ARTCAM and have succsesfully built new controllers for the motors which all work fine.
The Problem however is that when we turn the spindle on (a PERSKE spindle with its own controler) the Z axis moves up or down depending on it's last movement. We have derived that it maybe back EMF causing the stepper to move but short of putting a new spindle on what can we do.
I would like to keep the existing control boards KTA-263 from ocean controls http://www.oceancontrols.com.au/moto...ontrollers.htmand their breakout board. Do we need a different driver board or would sheilding the spindle be a better idea?
Thanks in advance.
Old 05-26-2009, 05:45 AM
cabnet636 is on a distinguished road
those are leadshine drivers, i had the same problem, ensure the wiring from the motor on z is correct and tight are you using the same motors and are they 4,6 or 8 wire steppers, are you using bipolar series or parallel ?
jim
James McGrew camaster x3, aspire software
www.mcgrewwoodwork.com
Old 05-26-2009, 06:53 PM
All the motors are the same and they all move atm.They are 8 wire Vexta's wired bipolar paralell. The manufacturer of the board seems to think opto couplers on the dir and step will fix the problem but??????
Old 05-26-2009, 07:09 PM
Al_The_Man's Avatar
What attention has been paid to proper grounding and bonding of the whole system?
It is could be likely that poor grounding rather than EMI in general is the cause.
Old 05-26-2009, 07:18 PM
have you got gecko drives?
jim
Old 05-26-2009, 07:22 PM
if it is only a problem when the spindle is on then i would look at grounding like al has said
jim
Old 05-27-2009, 04:35 AM
Smile
seems we have succes ; yes all grounds were good ,breakout and stepper boardswere being powered by the power supply of the pc (brand new) and they are also mounted inside this same pc. Solution; chaged power suply for the boards buy using external power suply and moved the power/control wires for the Perske motor further away from the pc , thanks to all who replied
Need Help!- Stepper Motor doesn't spin but makes noise Finder Stepper Motors and Drives 10 06-03-2009 07:52 PM
Need Help!- What company makes great but cheap stepper motor? aaronwelder Stepper Motors and Drives 6 01-24-2009 05:53 PM
Who Makes The Best Stepper Controller? Willyb Benchtop Machines 10 12-05-2006 02:53 PM
Makes of stepper... Mat-C Stepper Motors and Drives 2 09-25-2006 01:19 PM
HELP! My stepper comes on but won't move. ljoe1969 DIY-CNC Router Table Machines 4 07-30-2004 08:03 AM
