| Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here! |
| Smaller Spindles? Does anyone know which ATC equipped spindle is the most compact? I am looking for something closer to the size of a Porter Cable than a fire-hydrant. Is there a way to modify/ upgrade a porter cable with ATC capability? |
| It is awfully quiet in here... I found a FIMEC spindle from ekstromcarlson, Model SM-C78 Spindle Motor, 4.7 HP at 18000 RPM, 220 Volts, 15.3 Amps $4500.00 Toolholders Not included Reactor (Recommended between drive and motor) $227.70 Variable Speed Drive (5HP, 220V / 1Ph / 60 Hz Input) $835.05 This spindle is still longer than I want. I think it was 491 mm or so, with the ISO 30 toolholder. I can spend more than this, I have but to find a shorter spindle... |
| Watch this seller: http://cgi.ebay.de/ws/eBayISAPI.dll?...tem=3867301088 When he have skimmed the market, the 4041 spindles will go for $500. (They did one year ago). But you will need the inverter to drive them. Make sure you budget to cover that. The 4052 is super for PCB routing+drilling. The 4041 can do heavier work (500W). The toolchanger will release tools up to 6mm shank. The collet stays in the spindle, but can be changed to smaller. That is a manual operation though. |
| Thanks for the link, I came into a 4052 spindle a few months ago and so far have not been able to find a suitable converter for it. Hopefully he'll have one for a good price . lol This hobby is the most expensive of all hobbies ive had so far |
| Try hsdusa.com.
__________________ No greater love can a man have than this, that he give his life for a friend. |
| Spindle proposal | fpworks | Benchtop Machines | 152 | 08-08-2008 01:25 AM |
| It's Smaller Than It Should Be!! | SIMONSIGNS | Kellyware CAM | 4 | 06-06-2005 06:32 AM |
| Spindles | eitanwaks | General Metal Working Machines | 1 | 05-28-2005 03:29 PM |
| Questions about milling spindles | Hack | General Metal Working Machines | 13 | 01-27-2005 05:42 PM |
