Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 04-13-2009, 05:32 PM
snwbrdr is on a distinguished road
PACER CNC
Hi Guys
Has anyone come across a CNC controller that has been converted from three phase to single phase? I have one and I want to change it back to three phase, inside the control box there is an inverter drive that turns the single phase input to 3 phase for the motors / spindle, will this be obsolete once converted back to 3 phase? Does anyone have a PACER HDS CNC? Any help would be great.
Old 04-15-2009, 11:20 AM
CNCMAN172 is on a distinguished road
Smile 1 phase to 3 phase
Snwbrdr,
You are asking if you can convert a machine running on single phase back to run on three phase power right? The VFD actually controls both the voltage and frequency coming to the spindle motor. Most VFDs can take 3 phase input and output 3 phase output. Some VFDs are capable of taking single phase 220v/460v input and convert this to a three phase output. The big question is why would you want to go back to direct three phase? The most logical answer is for a higher power spindle, as when you run a VFD on single phase you loose some percentage of its capacity.
If you go online and pull down the manual for your particular VFD you can verify it will run on standard three phase power being applied to the input of the drive. All you really need to do is make sure all three phase come into the input of the VFD, right now you probably have two wires, add the third missing phase and you will have all three inputs. Please consult your manual to ensure you particular VFD can run in this mode.
You do not want to remove the VFD and run the spindle on straight 3 phase power because you will not be able to adjust the frequency which allows you to control the speed.
Hope this helps.
CNCMAN
Old 04-19-2009, 04:53 PM
cheers for the help I will look into it
edgecam and a pacer router help!!! rally.sport EdgeCam 7 10-06-2011 02:33 AM
Flexicam or Pacer denise Commercial CNC Wood Routers 7 07-21-2010 09:32 AM
Pacer user in need of help Crugain General CAM Discussion 1 12-05-2007 03:24 PM
Pacer 3020HD Valuation UKStan Commercial CNC Wood Routers 1 09-22-2007 07:21 AM
Don't Buy anything PACER Dudded Aussie Vendor Discussion 3 09-14-2007 09:36 AM
