05-12-2005, 12:37 PM
Originally Posted by Carver The rigors of constant z-axis ( vertical ) moves required for carving has approximately the same effect os letting an impact hammer run on you gantry all day. The software that will fluidly do carving will be a little more expensive than most "milling" packages. Visual mill is a very good value that will allow you to do some fairly creative toolpaths to accomodate the complexity of cuts going through the grain in two directions at once.
Phill Pittman digicarve@verizon.net www.masterwerkes.com |
Phil,
Are you stating that Visual Mill does a good job smoothing the z-axis movement, or suggesting that it's an acceptable low cost tool that with a bunch of fiddling will allow you to get by? |
