| Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here! |
Recently, I rebuilt a Z-axis on my router, which has a p/n of 2300100400, and internally had a weird thrust bearing arrangement. I ended up modifying the thrust bearing assembly to use the same bearings I'm replacing X and Y with, which is the 7200B bearings from VXB, and created a new motor mount. The only remaining task will be to make a 1/2" spacer for the motor. In the mean time, I'm using simple standoffs. ![]() ![]() |
| So far I've waited a minute to see your finger.
It's about refitting the z-axis to use true angular contact bearings instead of the kluster kludge that techno implemented. Originally, they used 2 spherical bearings and washers. It's amazing how they spared no expense to provide a decent 5mm pitch ball screw and wasted all that hard earned investment on cheap radial bearings. The replacement bearings, ironically cost only $6.00 more per axis each but in this case, it was likely cheaper than the original, but correct. |
| Much better. thanks.
| I have some videos on YouTube and most are referenced in the operations manual. This is my operations manual It's actually a late 20th century machine all with double bearing slides, 4 shafts per axis. More images are online at http://www.oretek.com/images/ in the more recent folders. I've seen the LC4896 machine as one of my customers uses it , and odds are, it has the same z-axis defects. I'll know for sure on Monday, but odds are, if they're using spherical bearings, they're not really thrust bearings, and not too hot on tolerances either. |
| Tags |
| backlash, refurbish, repair, techno-isel, technocnc |
| Techno sys Router 4-axis | Spott3r | Mastercam | 3 | 03-30-2008 08:08 PM |
| Techno 5996 - 4th axis setup? | artparts | Commercial CNC Wood Routers | 0 | 06-05-2007 11:23 AM |
| 4 NEW CNC Routers From Techno Offer Heavy Weight Performance at an Amazing Price | carolpratt | Product Announcements & Manufacturer News | 0 | 12-05-2006 03:18 PM |
| Assembled Z axis for CNC routers | imserv | Product Announcements & Manufacturer News | 1 | 08-05-2005 10:34 PM |
| anyone know of the Techno routers? | tekno | General Metal Working Machines | 2 | 06-08-2004 10:36 PM |
