Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 12-06-2004, 07:02 PM
tltaylor is on a distinguished road
Unhappy Difference between a $70K and $12k router.
I guess I'm a little confused. I've been given the assignment at work to price out some smaller(3'x3') Cnc router for cutting into Trex style "wood material". We currently do this on a 4'X8' cnc with a 7hp spindle. So I get pricing from a company that makes large mills and a 5'x5', thier smallest, is like $70,000. What does a machine like this have over something like a ShopSabre for $12,000. both have the same z-travel, 5hp spindle and such. What's the deal?
Old 12-06-2004, 07:27 PM
Al_The_Man's Avatar
Check out Larken tables, they make a good product http://www.storm.ca/~larken/
Al
Old 12-06-2004, 07:41 PM
ger21's Avatar
I looked at the SHopSabre site, and for 12K you get a 4x5 with a 3HP columbo. A 5HP spindle and tool changer adds 10K more. The shopsabre is probably much lighter weight, and probably cuts much slower. Their cheapest vacuum system is 2K, a good one can run 7 to 10K. What are you comparing it too? A Komo or Thermwood or something like that?
Old 12-06-2004, 10:34 PM
I left the names at work so I will post them tuesday. The vacume system is a non issue for me as we have a large dedicated vac system for our vac.former and other mill. If i remember right the 3x3 system was $6900 + about 4K for the 5hp spindle set up. Wish i would have brought the pricing home, but I'll post it in the morning. Thanks for the advise.
Trent Taylor
Bullfrog International
Old 12-07-2004, 02:43 AM
Kmed is on a distinguished road
Look into a used motion master 4x8 or so. Most will come with either the AB 92 or 9600 or fagor 8040-8055 controllers. 7-15 HP spindles some with multiple spindles or tool changers. I know you can have a 4x8 used 5axis with twin heads ( 6 axis, 2 motors one 5 axis head one 3 axis head) for about $30k or so. If you are cutting wood they work great, and are built sturdy enough to make light but good cuts in aluminum, and any standard tooling boards..
Old 12-07-2004, 10:40 AM
Our 4X8 is a motion master with a 7.5hp spindle. We had a line on a used 5X8 a few weeks ago but it ended up selling for over $70k. If you see any in the 30K range let me know. I know from comparison of our motion master and the shopSabre that the SS is a lot lighter weight, but will a machine like SS break down more often or just not be able to cut materials like 3/8" plastic wood product? These are questions I will ask SS today, but I figured I'd ask the guys that aren't out to sell me machine.
Trent Taylor
Old 12-07-2004, 10:43 AM
I forgot to mention that we have been looking at DMI and Quintex machines if we go with larger more expensive units. Thanks for all the help. I don't post much but am learning alot.
Trent Taylor
Old 12-07-2004, 11:03 AM
buscht's Avatar
buscht is on a distinguished road
There are lots of differences between the 12k machine and 70k+ machine.
Before considering the machine, you should define your requirements better.
Are you cutting 2 shifts per day, 5 days a week, with maximum output being the criteria? Is the operator going to be anyone who is hired off the street? Or is this in a protoytpe area where quick turnaround is important. Are you a small shop where the operator, programmer, maintenance guy are all the same person?
I am sure that both machines will cut your TREX product. The higher priced machines may cut it 2 to 3 times as fast. They have stronger drive motors and are more robust. Another benefit with a more commercial type machine is the multiple router heads/ drill heads. They are more versatile for production components.
Accuracy might be a factor, I'm not real familiar with the Shop Sabre, but check the specs on all machines for accuracy and repeatability.
A point to point router/drill might also work well on your TREX material. Used ones are available for around $30-40K
Old 12-07-2004, 02:20 PM
Thanks buscht,
All very good questions. We are actually a hot tub manufacterer and use the "plastic wood" on the cabinets of our tubs. Only the door panels are machined so we are looking at around 50 doors per day between two shifts(25 per) which gives me a 18-20 minute per door cut time on a dedicated machine. The current process takes about 5 minutes on our motion master, which is pulling a lot of duty on other projects. We work 50+ weeks a year, 5 days a week, 2 shifts.
We are not dealing with exteme close accuracy issues and I think all the smaller machines are accurate to about .05" or better. Ease of operation is important. A dedicated door panel machine would lower the skill level because no change of probram or tooling would be involved. Just plug and play basically. And this operation is agian just a 3-axis machine. I am also starting to look for a small 5 axis machine(18"X24"). Oh the fun. Thanks agian for the help.
Trent Taylor
www.bullfrogspas.com
Old 12-07-2004, 03:05 PM
buscht's Avatar
Trent, At your volume levels and accuracy requirements, a Shop Sabre, Shopbot, Techno Isel machine will work well.
You stated that you want it simple. You should really get a dedicated vacuum pump for this machine or at least some dedicated way to clamp the parts down. Sharing between equipment is asking for problems.
The trick is to let the machine cut at about a 10 minute cycle, improve your load and unload procedures, and have the operator do some secondary operations during the machine cycle.
Good luck
T
  #11   Ban this user!
Old 12-08-2004, 06:59 PM
I posted, but it must not have come through. Our 4x8 is a Motion Master 5 axis with 7hp spindle. We thought we might be able to pick up a used one cheap since they aren't around anymore. We found one last month, single head, single table and the guy wanted $70k. We called his bluff and he sold it the next day. If you see any around for #30K let me know. Plus we would like something smaller and more user friendly. Thanks for the help.
trent taylor
  #12   Ban this user!
Old 12-09-2004, 11:26 AM
ViperTX is on a distinguished road
Okay, I'm being a wise-ass...but the difference between a $70K and $12K router is $58K....so, from a business point-of-view if I bill out the router and operator combo at $100 an hour....then I might possibly be able to justify a total downtime of 580 hours...spread this out over the life of this capital asset...say 5 years and I can afford about 116 hours of down time per year (basis calculation, no interest, no future / present value of money, etc.) The machinery dealer should be able to ballpark the downtime required on an annual basis for maintenance / repair ....compare that and the price difference.
