Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 12-05-2008, 03:47 PM
joeyg is on a distinguished road
Cooling liquid for SUDA SD1208?
We bought thru alibaba.com a CNC router from SUDA corporation.
We are located in Italy. SUDA is located in China.
The CNC router is the SD1208 (see picture).
We are in the process of setting up the machine. So far almost everything OK.
They gave us a very concise and limited user manual. So far it seems that they have little idea of customer service.
Right now our major doubt is which liquid to use to cool off the spindle. Anybody has any idea? Buddies are telling us that using the wrong cooling liquid might cook up the spindle motor real fast.
Anybody has the same machine? Same problem?
We are going to use it mostly for aluminium sheets 5mm.
Old 12-05-2008, 05:53 PM
Big S is on a distinguished road
You should use a coolant with ethylene glycol in it, The same stuff that is used in car radiators. Doing this stops the insides of the spindle from corroding and damaging it. The ethylene glycol / water mix should be similar to what is put in a car radiator.
Edit, if you are meaning the liquid to cool the cutters, you can use a water soluble cutting fluid mixed with water at a very high water to cutting fluid ratio. Another option is to use methylated spirits, but sometimes this can damage the plastics in the mister equipment if it is a low grade of meths. I personally would use the methylated spirits as it leaves no residue on the aluminium. You can also use plain water when cutting plastics to increase cutter life. Be aware that methylated spirits should not be used on acrylics as it can cause cracking when the acrylic ages.
Shannon.
Excitech 1530 Router owner,
WWW.REMAIN.CO.NZ.
Old 12-05-2008, 06:04 PM
ger21's Avatar
When those spindles are offered separately, they usually say to use tap water for coolant.
http://www.homeshopcnc.com/HFspindle2.html
Old 12-10-2008, 06:19 AM
Hi guys.
Thanks for the help!
We are going to experiment with glycol and water. Where we live the tap water is too hard.
We found also some info here:
http://www.dongfangxueshi.com/english/down.htm
Old 12-29-2008, 06:56 AM
This is our final cooling setup:
We found out at last that the two clothing boxes that the vendor used in the shipping to pack tools and documents were also intended to be used as tanks. They sent us an email with some instructions. With some surprise we finally submerged the aquarium water pumps provided with the machine into those boxes, used glycol water and we have begun machining with this setup. So far it works.
Customer service, with the vendor (Suda) is going from bad to worse. I am thinking to open a thread about it.
Liquid inlay DougO WoodWorking 12 05-26-2007 07:53 AM
Liquid joinery ThomD DIY-CNC Router Table Machines 4 02-17-2007 02:16 PM
Liquid foam? slawsonb Casting Metals 12 01-17-2006 03:44 AM
Is there any cooling liquid homemade formula? jlagran he General Metalwork Discussion 3 12-14-2004 09:33 AM
Glueing bolts in...Liquid lock-washer? samualt DIY-CNC Router Table Machines 3 10-04-2004 11:32 AM
