Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 12-02-2008, 06:13 PM
johnono is on a distinguished road
Techno Isel Software
Hey, I have a TECHNO ISEL and I'm planning to run on a new computer, the old one now is a mess probably 10 years old, so I need to know what the software is for this and where I may be able to find it. All the info I have is here..
ISA Card = h20t43-srv400
controller = h26t56-srvbox2
Please and thanks
Old 12-02-2008, 07:10 PM
cabnet636 is on a distinguished road
have you contacted techno?
jim
James McGrew camaster x3, aspire software
www.mcgrewwoodwork.com
Old 12-05-2008, 11:57 AM
They said I'd need to buy the new PCI card, which would be $1700, and at this point I don't even know if the controller I have will work for this anyways.
I just want to see what the machine I have is capable of, but the computers I have with ISA card slots aren't starting up with this hard drive which has the info I need, and I can't check the hard drive on a newer computer to see what software is on it. So if anyone has any suggestions into where I can find any of this old software it would be appreciated.
Old 12-05-2008, 01:49 PM
Found software from the old hard drive. It's called SAC.exe
Only loads .sac files. Where can I find a program that makes .sac files, and what is a .sac file anyways?? so confused. I want to be able to make a program from Bobcad or something, and load into this SAC program to be able to run on my techno isel machine.
Old 12-05-2008, 02:21 PM
harley4ever is on a distinguished road
Buyer beware! Bobcad beware!
Old 12-05-2008, 02:27 PM
Haha, I've only ever used bobcad and become familiar with it, but this dolphin you speak of same idea?
Old 12-05-2008, 03:13 PM
I use both surfcam and dolphin. Surfcam at work for our mill. I have my own small shop at home (plan to eventually make it full time). I personally think dolphin is much better. I bought bobcad 2 years ago and refuse to ever even think of buying again. Between bugs, them calling 24-7, nickel and diming me for everything, support, it was just a nightmare.
Old 12-05-2008, 03:33 PM
True, I'm using Bobcad V20, theyve got V23 out now and pressure you into trying it then buying it while I'm already just used to learning V20, and fine with it. It has been countless times calling their customer support for problems. What's the cost of dolphin? and is it basically same idea?
Old 12-05-2008, 03:55 PM
When I bought my software from dolphin, I got hobby pricing. It isnt 100% hobby for me as I soon intend to make it full time. I have been carrying quite a workload and can barely make do with the time I have. Yes it is the same though in regards to both being cad cam.
Old 01-02-2009, 08:19 PM
rhipps is on a distinguished road
Techno Isel
I also had a similar problem with a Techno table that I got from my employer. The controller was completely burned out. I solved the problem by replacing the controller with a unit from simple CNC for about $100. The motors needed to be wired differently but this only took about an hour. I am running Mach 3 software which works well, I still learning. Hope this helps.
  #11   Ban this user!
Old 07-28-2010, 02:33 PM
la_arts is on a distinguished road
techno controller options
Did you ever get a solution to your problem? I have a techo with the same setup but lack the pci controller card. I am looking for options other than the 1700 pci card...
thanks,
steve
  #12   Ban this user!
Old 07-29-2010, 07:08 AM
I still have the computer that was originally hooked up to system. Want me to look? see if card is still workable?
Need Help!- Techno isel servo amp... cuemaker1 Want To Buy...Need help! 2 12-15-2008 08:26 PM
Software recommendation for Techno-Isel 4848LC KIE7 General CNC (Mill and Lathe) Control Software (NC) 3 10-02-2008 07:54 PM
Techno Isel cuemaker1 Commercial CNC Wood Routers 5 12-14-2007 06:51 PM
Techno Isel wood_donkey Commercial CNC Wood Routers 2 04-19-2007 06:13 PM
Techno-ISEL MAC 100 software? wmb General Metalwork Discussion 0 08-09-2006 03:39 AM
