| Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here! |
I have a Practical CNC and want to mill a mold for a boat keel out of aluminum. Once I finish the 3D bulb, I will cut it in half to subtract the 3D solid from a block. When generating tool path, what is best tool to do the work with? I have round end 1/4", 3/8" and 1/2" bits. Would I be just as well off with the 1/2 with small steps between passes? What depth steps? What step overs? What is the best route to do this? Thanks in advance. Sam |
| what software are you using? just how big a mold are you doing? i looked back at your site and looks like you are doing some really cool stuff, you could do this with aspire and just make the two halfs. step over for smooth finish with a ball nose is 10% or less, i would test it first jim jim
__________________ James McGrew camaster x3, aspire software www.mcgrewwoodwork.com |
Mold is torpedo shaped with slot cut out of it for the keel fin to fit in. Bulb is 1350 mm long and 212 mm at largest diameter. I use Bob CAD CAM v 21 and WinCNC with a PracticalCNC Router. On the step over, 10% of bit width? i.e. with 9 mm bit, step .9 mm? Thanks for all the comments. Sam |
| i aalso have bobcad 22 but do not use it (fell in love with vectric quick) and have wincnc, you should have no problem, my only suggestion is get thick pink or blue insulation foam glue laminate it to thickness then test your tool pathing! jim
| aluminum forming...press mold? | mc-motorsports | Bending, Forging,Extrusion... | 9 | 08-17-2008 12:10 AM |
| Velocity stack aluminum mold - how would you do it | SuperRunner | Moldmaking | 8 | 09-25-2007 10:20 AM |
| Texturing an aluminum mold? | tenaja | Moldmaking | 2 | 11-26-2006 07:15 PM |
| Aluminum Mold | hurricane1001 | Moldmaking | 9 | 11-27-2005 08:41 PM |
| test mold in aluminum | gcz | Moldmaking | 5 | 10-19-2005 03:23 AM |
