Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 11-28-2008, 05:07 AM
bogger44 is on a distinguished road
Router bits, End mills v bits
I have router bits straight spiral bits.
But what do you guys use for end mills, are these for a milling machine that you cut steel with? Ball end mills ect.
Where can I get some?
Old 11-30-2008, 10:48 AM
todd71's Avatar
todd71 is on a distinguished road
There are lots of places to get tooling Online (enco,msc,vortec). There may even be a local tool grind shop in your area. Just depends on where your at. Google "tool grinding Canada". Or some variation and you bound to come across something.
I get my tooling at http://pgm-tools.com/ Which happens to be down the road from us. Metal cutting tools will work fine for wood or HDU.
Gets a little different when you cut acrylic, plastic, etc.
I use an "O- flute" (single flute).
Most my side cutting tools are 2 flute and 3 flute for v-carving.
A) 1/2: up shear end mill
B) 1/2: compression
c) 1/2: down shear
D) 1/8: 5 deg taper (draft)
E) 1/2: Ball endmill
F) 3/16: Ball mill 5 deg taper (draft)
G) 1/2: 90 deg included angle (v-carve)
H) 3/4: 120 deg included angle (v-carve)
Hope this helps.
Todd
www.innovative-accents.com
ID:	70660   Click image for larger version
Name:	TOOLING ALT VIEW.jpg‎
Old 12-03-2008, 11:35 AM
bits
Thanks I seen pieces cut with a ball end mill and could'nt find any on the wood cutting sites.
Old 12-03-2008, 12:06 PM
Astonlee's Avatar
Astonlee is on a distinguished road
Milling cutters suppliers
If you want some good quality tools try these as the have a Canadian office http://www.sgstool.com
Which Router bits to Use joecnc2006 WoodWorking 7 05-06-2011 05:06 AM
router bits luther DIY-CNC Router Table Machines 1 09-03-2007 06:50 PM
Yet again about router bits. Konstantin WoodWorking 5 12-08-2006 09:31 PM
Router Bits in OZ Exelanoz Australia, New Zealand Club house 4 11-17-2005 08:41 PM
End mills engraving bits signIT General Material Machining Solutions 3 09-12-2004 10:45 PM
