Results 1 to 7 of 7
Thread: Help with SR 23 Table top router
    Aug 2008
    USA Alabama
    I am using VectorArt 3d and trying to save a toolpath however my machine is not in the list (go figure) : )
    I have an SR 23 (aka CAMaster Stinger) can anyone help me find the correct *.nc to pick
    Anthony
    Mar 2003
    Shelby Twp, MI....USA
    I'm assuming it's controlled with WinCNC? If so , is there a WinCNC post?
    Aug 2008
    USA Alabama
    Sorry, I didn't understand what my question was : )
    Actually my machine uses NCStudio. Guess this is a better question for them to answer?
    Anthony
    Mar 2003
    There website lists a different one. Call Camaster and see what they recommend.
    Aug 2008
    USA Alabama
    I just heard from them after this post. They said to pick the G Code mm *.tap file and rename it to a .nc file.
    However, now I really scrued up. The software that my system uses is NCStudio. Something on it was messed up so I reinstalled it. When I went to run the machine the spindal went out of the Z zone. Yeap... all the setting have been changed. When I called CAMaster, they have no clue what the settings are. So now I am done yet again (I think this is like the third time I can't do something because of the machine) First, the settings that were given to me were wrong. Then I broke the only bit I was given for the machine and when I got others I found out that it was metric. So I had to order (actually a friend got me one) another collet. And now the setting in the software again.
    If you have an SR 23 and use NCStudio please let me know.... : )
    Anthony
    Aug 2008
    USA Alabama
    It is actually controlled with the NCStudio. I did what Josh said and it worked out fine. The problem I was having actually came from the home position for Z. Some reason it keeps switching on me. I have it set at the lowest.. something like .237 but it was now at 2.0... How the heck it got there I have no clue.
    Anthony
    Attached Thumbnails Attached Thumbnails Help with SR 23 Table top router-chief_plate.jpg
    Oct 2007
    excellent!!
    i did not carve my first 3d untill i had mine 4-5 months
    jim
    1. my router table
      By thekydd in forum DIY CNC Router Table Machines
      Last Post: 04-05-2009, 11:34 PM
    2. Need Help!- Router Table help
      By ripper7777777 in forum General Metal Working Machines
      Last Post: 03-26-2008, 11:52 AM
    3. 80/20 for diy router table?
      By mjs79 in forum 80/20, TSLOTS and other Aluminum Framing Systems
      Last Post: 09-23-2007, 01:17 AM
    4. 4 x 8 router table
      By lumberjack_jeff in forum Open Source CNC Machine Designs
      Last Post: 06-02-2006, 08:25 PM
    5. router table
      By planescott in forum Mechanical Calculations/Engineering Design
      Last Post: 01-16-2006, 01:49 AM
