| Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here! |
| We have a Shopsabre with the lathe 4th axis. We haven't used the 4th axis much, and in fact for several years. I'm trying to understand the g-code for it. This is what I know form dinking around with it. W 0.0000 to W 18.7000 gives me from what I can tell a complete rotation. I'm thinking this has more to do with the circumference than with degrees. So anyone that has an explanation of G-code for the 4th axis would be greatly apreciated. |
| With Mach, I can change the parameters for travel. For instance, I manually set steps per inch (10,000 in my case) for a linear axis. It sounds like you might want to change the parameters for your 4th axis. Some cam programs output axis rotations in Radians (57.3 degrees per radian or so), and some in degrees (360 in a rotation) My rotary table has gears in it, so I had to figure out how many turns of the servo made a complete rotation, and back track from there. Are you using Mach? |
| ok trevis, in our group of routers wincnc is widely used and there are several guys who are a lot more adapt at explianing this than i, i have both mach and wincnc and find both extremly well built programs i can change my winini file for whether i am carving or driving through plywood josh glen has written a calculator for setting resolution that i use a lot, i'll see if i can find you some guy's who can help you with this at the bottom of this page is a calculator i am glad i have!! http://www.joshuaglenn.com/jgblog/in...ine-tutorials/ oh paul, josh todd ? it's sat night so it might take a minute!! |
| I was thinking the W axis would be like The X Y and Z axis. Where would go by increments of inches. Or maybe with the W axis degrees or radians. Maybe that's not the case and it's per step. All the motors except the W axis are servo motors. |
#11
Sorry,I dont know anything about 4th axis for SS. |
| Propellers on a Shopsabre | Piet propeller | Commercial CNC Wood Routers | 24 | 12-10-2010 11:04 PM |
| shopsabre Accuracy | ro7all | Shopsabre | 43 | 03-30-2009 07:38 PM |
| New shopsabre | BensMillwork | Shopsabre | 27 | 01-17-2009 11:35 AM |
| Shopsabre ATC Probblem | dsgnkrft | Shopsabre | 3 | 11-05-2008 09:03 PM |
| Posting to ShopSabre | robinsoncr | Mastercam | 2 | 07-09-2007 10:58 PM |
