| Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here! |
Hello, I have a new Techno tabletop router with a Porter Cable spindle, I need to fit the vacuum shroud that is held on to the spindle block with a metal bar. There is hole with a bushing (looks like brass) in the spindle block where the metal bar slides through and is held in place by a thumbscrew. The bushing was tight and the bar needed some taps with a metal hammer to go all the way up, I used a piece of wood on the edge of the metal bar so it would not be damaged. The Z axis was all the way up to the limit of travel, could the blows from fitting the bar through the spindle block damage anything (servos, limit switch, ball screw)?. Thanks in advance, Hugo |
| Vacuum table and vacuum pump | garagefela | DIY-CNC Router Table Machines | 19 | 01-25-2012 10:30 AM |
| Re-fitting a mill | gunner312 | Benchtop Machines | 1 | 07-11-2007 09:31 AM |
| M6 x 1.0mm grease fitting | N4NV | Mechanical Calculations/Engineering Design | 5 | 03-31-2006 04:03 PM |
| Retro fitting | new2this | Industrial Hobbies (Support forum) | 1 | 01-21-2006 06:21 PM |
| cnc fitting a bridgeport | MBG | Bridgeport and Hardinge Mills | 5 | 09-26-2005 04:25 PM |
