Originally Posted by
mlind
My 2nd Machine from Thom Carr,
I have been putting my 2nd Machine through the paces and it has been running about 3-4 hours per day since my previous post. I had/have some issues with the Z Axis and until I slow down to adjust it I can live with this minor problem.....I have raised the table to compensate for the Z-height issue. Basically the Z axis jams when going all the way to the top of the rails. I have been cutting only 4 different repetitive patterns since I received the machine and it has performed very well no major issues. This is out of the box with no adjustments made to the machine. I am sure the Z Axis problem is probably a simple fix but I need the machine running for now so I'll update this when I actually have time to delve into the problem which looks like an alignment problem.
The big machine is still kicking butt and taking names although I pushed it a little hard like a dummy and cracked the bearing supports. Temporary fix in place and still running. I need to holler at Thom and get some parts when I can afford the down time which isn't foreseeable in the near future.
I am considering a 3rd machine if I can figure out a place to put it. My Garage shop is fast becoming a manufacturing facility. Too much work and not enough equipment. I'm sorry to hear the problems that others are having with their machines. I dunno, it doesn't' make sense on how my equipment is running so good and others are having so many problems? I see speed is a constant with everyone who is having problems. Perhaps that is why my machines run so well. I don't cut any faster than 30ipm. When I use a 1/2 bit I cut at 25ipm. I'm curious as to the how fast others are cutting at and the depths of cuts. I don't cut any deeper than 1/4 inch per pass.
Whenever I call Thom he is always there for support and he has never let me down. When I need parts I get them about 2-3 weeks after I let him know about the problem. hmmmm Leaves me itching and scratching. I wish I was close to see some of these problem machines as I am really curious..
BTW... Any machines you guys don't want holler at me. I am looking to buy another one... I'll only buy a Thom Carr machine. A used machine with problems suits me just fine, of course if the price is right.
Just thought I would update this thread.
I just bought a (2nd) new machine from Thom Carr and so far out of the box it has performed very well. No damage to the shipping crate this time. Some minor tweeks here and there and it is cutting excellant. Thom has re-designed the rails and from what I see so far it is an improvement over previous designs. My first machine is still making money and I have had so many orders I needed 2 machines running hence I bought the 2nd machine.
I saw a comment somewhere that stated this machine wasn't good for commercial use. Hmmm... My 4x4 machine has been running about 20-40 hours per week for the past year with no major issues. I'll update this once the new machine has ran for more than a couple hundred hours, probably next month.
