Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 08-14-2008, 11:54 AM
lclore is on a distinguished road
Question Kress Milling Motor
After lots of research, I am preparing to finalize the purchase of a BZT CNC Router Machine. They offer it with a Kress Milling Motor, which as best I can tell, is rated 220V 50Hz only. I like the narrow profile of the Kress- is anyone running it on 120V/60Hz? I can do a step up x-former or a VFD (assuming 3~ Input) but would rather not if I don't have to. I can't find an english manual and am interested in others experiences. THANKS!!
Lee
Old 09-07-2008, 10:30 AM
woodturner550 is on a distinguished road
Lee,
I have the Kress milling motor manual in english. Don't have the motor yet.
The manual is in pdf form.
Send me your email addresss and I will send it to you.
Leonard Dye
woodturner550@clearwire.net
Old 09-07-2008, 11:10 AM
great thanks, I appreciate that...
onyxindustries@gmail.com
Old 05-01-2009, 05:39 AM
*Registered User*
marchantdice is on a distinguished road
Kress 240V and 110V and outline drawings
We www.worldofcnc.com have stock...
1050 FME 240V, 800 FME240V, 530 FM 240V and 800 FME 110V...
To help you design in a Kress we have the outline drawing, please request via email....
Old 05-02-2009, 07:21 AM
rrdiaz30 is on a distinguished road
I purchased one from Kevin (Marchantdice) on EBay. The price was the best as compared to others, and the shipping was fast. I had to change out the electrical plug but that was very easy to do. I would recommend buying a collet clamping nut for every collet you have as it is easier to swap out collets with the nut already attached. K2 CNC also is selling a nice mounting bracket for the Kress on EBay.
Rick
Old 08-20-2009, 04:25 AM
kostas1 is on a distinguished road
Is Kress 1050 ok?
I am to buy a kress 1050W spindle and I would like to know if it can be used for professional daily production (probably not amateur use)...
Also, can it route in diferrent materials and what speeds can it sustain in wood giving that its attached bit is ok?
Thanks...
Kostas.
Old 08-20-2009, 05:50 AM
*Registered User*
Kress 1050 FME running 24/7
The Kress 1050...we have Industrial manufacturing customers using these motors 24/7. Purchase an additional set of brushes as running 24/7 these will wear within 6 months...
Power input 1050 Watt / 240V
No-load speed / Idling 10000 - 32000 r.p.m.
Available Clamping jaw / Collets: 1 to 8mm
Mounting Ø 43 mm
Weight 2.4 kg
Materials: Engraving of steels
Machining: All soft alloys ets ie. brass, bronze Ally
Wood: All
Plastics: All
More information: http://www.marchantdice.com/forum/vi...18f24673511705
Originally Posted by kostas1 View Post
Thanks...
Kostas.
Old 08-20-2009, 08:47 AM
I think you mean these brushes right?
Also, I think the weight is 1.4kg and not 2.4kg....
Are these customers satisfied with this model?
Kostas.
Old 08-21-2009, 04:04 AM
*Registered User*
Kress 1050
I have just weighed the Kress 1050 is 2.4kg including the light packing carton.
Customers are very satisfied with this model and the 2 year warrantee...excluding "wear parts" http://www.marchantdice.com/forum/viewtopic.php?t=441
Brushes: http://www.worldofcnc.com/products.asp?recnumber=95
Kostas.
Old 08-21-2009, 07:51 AM
Kress in Speed?
ok...you mean that the total package weighs 2.4kg, but the tool-weight is 1.7kg according to the constructor
I hope this kress will do my job...my table will be 1.5mX1m, the gantry will weighs about 20kg, and my motors are strong enough (640oz-in),1610 ballscrews will be used so I think that I'll manage to have quite a big speed...
Will Kress 1050 be able to keep up with this?
Kostas...
Old 08-21-2009, 07:58 AM
*Registered User*
Hi, Machine feed rate / suitable Kress...
This also depends on the material are you machining and tooling used?
  #12   Ban this user!
Old 08-21-2009, 08:18 AM
Sorry, what you mean by "Machine feed rate / suitable Kress..."?
Generally I 'll use mostly wood and tools for milling, graving and finishing the object...
Kostas.
Need Help!- Hi, I'm new here, and need some help with KRESS router Tadas25 DIY-CNC Router Table Machines 4 07-08-2008 12:52 PM
Kress 800FME collets? altis Wood Working Tooling 2 06-02-2008 03:44 PM
kress router brianna187 Want To Buy...Need help! 0 04-28-2008 10:23 AM
buy Kress 900 in Europe ikkedus Mechanical Calculations/Engineering Design 5 01-28-2006 11:06 AM
