Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 08-12-2008, 11:57 PM
jeremy budgen is on a distinguished road
Biesse
Is there anyone out there in cnc land that has a Biesse type machine
Regards
Jeremy
Old 08-15-2008, 01:48 PM
battwell is on a distinguished road
yup. me!
rover 321 r atc
Old 08-15-2008, 11:17 PM
battwell
Is that a Rover b2.3 if it is we have the same baby.
What sort of things are you doing, maybe we can exchange files.
I am busy setting up Bobcad to do 3d work on mine, having a few issues with the posy processor, only mina ones though.
Jeremy
Old 08-16-2008, 04:25 AM
i wish! mines a 1994 machine. only handles a max 11k program so its useless for big files. i make pool tables with it. it does what it was designed to do very well, ie route, drill, saw but the memory restriction is a pain in the ass to work around, i have to split files and run them one after the other
im thinking about refitting the axis controls only to mach, using the old controller to do all the other bits, tool change, speed control etc.
the main downfall is it only has 60mm max under the router to vacuum pods so unless you make a u cradle the height is limited.
im designing my own 8by 4ft super fast machine now, running on mach with high powered servo drives and a 2ft z axis.
Old 08-19-2008, 10:10 PM
Battwell
Are you making the new cnc from ally or what.
If are you cutting the ally on the rover or having it cut elsewhere.
Here what we make here www.jmbfurniture.com, if you want any files just let me know.
Where are you based, i am in South Africa.
Jeremy
Old 08-23-2008, 01:22 PM
il be assembling my "creation" from pallet racking framework which just bolts together with very strong sections. i made a 10ft long double gang press and laminate postformer from it a few years ago, to wrap laminate around a bullnose section. see www.mercuryleisure.co.uk to see what i make.
i have all the servo motors etc here and a nice rack/pinion unit which is 16ft long. im hoping to use belt drive for the y axis and maybe even the z axis.
im designing this to do both routing and plasma cutting so its going to be a multi tasking weirdo a bit like me.
based in the uk, but will be using lots of parts from over the pond.
Old 08-24-2008, 12:17 AM
Battwell.
I am actually from Farnham in Surrey, moved to SA About 12yrs ago.
I also built my first cnc machine to take a full sheet of 9 x 6 gantry type, don`t use it much these days and thinking about taking off the motors etc and retroing to a metal working lathe or to use the gantry side of the machine and creating a frame work to hold a traditional wood working lathe underneath the gantry. Just hav`nt decided yet which way to go, I also built a wrapping machine to make wrap doors for kitchens and bedroom furniture.
If you need any help with your setup let me know and if i can help i will.
Maybe it is possible and if you are willing, can you supply me with a set of plans of a pool table as my son has been asking for ages if i could build one for him and i do not have any of the correct dimentions, do you use dxf format for the machine.
Best regards
Jeremy
Old 08-24-2008, 05:18 AM
re pool table making. if only it was that easy.
1: i struggle to draw a matchstick man.
2: my machine has an 11k program limit so cad cam produces programs too big for it
basically all my drawings are on notepaper which i then parametrically program into the machine by hand. (this way i can make all sizes from 1 program just changing a few numbers)
some parts are too wide for my machine so i have to turn them around!
i can send you my code, but your machine may or may not read it. my controller is the old cni 481. yup, pain in the ass floppy powered!
so basically i dont have dfx files i can send.
i can help with dimensions etc.
i will read in some code and paste it to you.
funny enough i have also been designing a lathe attatchment to sit at the end of my rover. its designed with a "u cradle" to fit between 2 sets of pods at the end of the machine, thus allowing enough clearance to turn. mines designed for a max swing of 10" with 18" between centres (enough to turn pool table legs)
the programming is quite simple then using x to position over centre, y for length, z as normal.
im a bit slow getting it finished as im working alone at the moment as cash flow is slow in the uk. so if im not designing im programming, machining, assembling, delivering or doing paperwork. oh, and sometimes i get to sleep too.
Old 08-24-2008, 05:39 AM
; AA=SLATE SIZE BB=FRAME CC=BOLTSPACE DD=BOLT FROM CENTRE EE=BOX FROM SLATE
N20 AA=1905 BB=115 CC=363 DD=98 EE=50
N30 XO=BB YO=BB
N40 L=GC1 UT=1
N50 X=-BB-10 Y=-BB-15 Z=PRK PRF=LPZ/2 F6 G41 TP1 L=PON
N60 G1 X=-BB Y=-BB
N70 G1 BS- BA45
N80 BT+ I7 J7 G3
N90 G1 X61 Y0 BA45
N100 G1 X=AA/2-51
N110 G1 Y-3
N120 G1 X=AA/2-42.5
N130 G1 Y0
N140 X=AA/2+42.5 Y0 I=AA/2 J0 G3
N150 G1 Y-3
N160 G1 X=AA/2+51
N170 G1 Y0
N180 G1 X=AA-61 Y0
N190 G1 BT+ BA315
N200 BS- I=AA-7 J7 G3
N210 G1 X=AA+BB Y=-BB BA135
N220 G1 X=AA+BB+20 Y=-BB-10 G40
N230 L=PSU
N240 X=-BB-10 Y=-BB-15 Z=PRK PRF=LPZ F5 G41 TP1 L=PON
N250 G1 X=-BB Y=-BB
N260 G1 BS- BA45
N270 BT+ I7 J7 G3
N280 G1 X61 Y0 BA45
N290 G1 X=AA-61 Y0
N300 G1 BT+ BA315
N310 BS- I=AA-7 J7 G3
N320 G1 X=AA+BB Y=-BB BA135
N330 G1 X=AA+BB+20 Y=-BB-10 G40
N340 L=PSU
;HOLE R
N350 X=AA+20 Y-85 Z=PRK PRF=0 F4 G41 TP1 L=PON
N360 G1 Y-61 Z=-LPZ/2+5
N370 Y-61 I=AA+20 J-75 G3
N380 G1 Y-57.5
N390 Y-57.5 I=AA+20 J-75 G3
;N159 G1 ZI+2
N400 Y-57.5 I=AA+20 J-75 G3
N410 G1 Y-75 G40
N420 L=PSU
; HOLE L
N430 X-20 Y-85 Z=PRK PRF=0 F4 G41 TP1 L=PON
N440 G1 Y-61 Z=-LPZ/2+5
N450 Y-61 I-20 J-75 G3
N460 G1 Y-57.5
N470 Y-57.5 I-20 J-75 G3
;N159 G1 ZI+2
N480 Y-57.5 I-20 J-75 G3
N490 G1 Y-75 G40
N500 L=PSU
N510 XO=AA/2+BB-DD-CC-CC L:1
N520 XO=AA/2+BB-DD-CC L:1
N530 XO=AA/2+BB-DD L:1
N540 XO=AA/2+BB+DD L:1
N550 XO=AA/2+BB+DD+CC L:1
N560 XO=AA/2+BB+DD+CC+CC L:1
N570 XO=BB YO=BB
N580 L=POFF
N590 L=GC1 UT=4
N600 X-20 Y-75 Z=PRK PRF=LPZ/2+1 F4 G40 TP1 L=PON
N610 G1 BL40 BA135
N620 L=PSU
N630 XO=AA/2+BB-DD-CC-CC L:2
N640 XO=AA/2+BB-DD-CC L:2
N650 XO=AA/2+BB-DD L:2
N660 XO=AA/2+BB+DD L:2
N670 XO=AA/2+BB+DD+CC L:2
N680 XO=AA/2+BB+DD+CC+CC L:2
N690 XO=BB YO=BB
N700 L=PSU
N710 X=AA+20 Y-75 Z=PRK PRF=LPZ/2 F4 G40 TP1 L=PON
N720 G1 BL40 BA45
N730 L=POFF
N740 L=GC1 UT=3
N750 X=AA+BB+20 Y=-BB+40 Z=PRK PRF=0 F4 G41 TP1 L=PON
N760 G1 X=AA+BB Y=-BB+40
N770 X=AA+BB-40 Y=-BB I=AA+BB-40 J=-BB+40 G2
N780 G1 Y=-BB-20 G40
N790 L=PSU
N800 X=-BB+40 Y=-BB-20 Z=PRK PRF=0 F4 G41 TP1 L=PON
N810 G1 X=-BB+40 Y=-BB
N820 X=-BB Y=-BB+40 I=-BB+40 J=-BB+40 G2
N830 G1 X=-BB-20 G40
N840 L=POFF
;N240 G1 X=-BB+30 Y=-BB
;N250 G6 X=-BB Y=-BB+30
;N251 G1 X=-BB-10 Y=-BB-10 G40
N850 L=GC1 UT=1
N860 X0 Y0 Z=PRK PRF=LPZ F4 G41 TP1 L=PON
N870 G1 X61 Y-4
N880 G1 X69
N890 G1 Y-.1
N900 G1 X=AA-69
N910 G1 Y-4
N920 G1 X=AA-20
N930 G1 X=AA G40
N940 L=POFF
N950 X=AA/2-719 Y-38 PRF=5 T11 L=G99
N960 X=AA/2-681 PRF=5 T8 L=G99
N970 X=AA/2-281 PRF=5 T11 L=G99
N980 X=AA/2-319 PRF=5 T8 L=G99
N990 X=AA/2+281 Y-38 PRF=5 T11 L=G99
N1000 X=AA/2+319 PRF=5 T8 L=G99
N1010 X=AA/2+681 PRF=5 T11 L=G99
N1020 X=AA/2+719 PRF=5 T8 L=G99
N1030 X=PRK Y=PRK
:1
N1040 X0 Y-75 Z=PRK PRF=0 F4 G40 TP1 L=PON
N1050 G1 Y-30 Z=-LPZ/2+3
N1060 G1 XI10 ZI10
N1070 G1 XI-20
N1080 G1 XI10
N1090 G1 Y-75 Z=-LPZ
N1100 L=PSU
:2
N1110 X0 Y-30 Z=PRK PRF=0 F5 G40 TP1 L=PON
N1120 G1 Y1 Z=-LPZ/2
N1130 G1 Y-30 Z=-LPZ/2+3
N1140 L=PSU
Battwell
Basically the 481 is the xnc500 or xnc1000, which will work on my machine as i have the old programming editor on my machine and also biesseworks.
I suppose all i would need would be the dimentions of the base table and the section of the side ribs and radious of the pocket holes and then i could create the table from there on my own, but if you could scan the notepaper and send me a smaller file of the jpg file that would also surfice.
I hadd`nt thought of using the rover for a lathe as well ???? maybe.
Jeremy
  #11   Ban this user!
Old 08-24-2008, 05:43 AM
thats a youtube video i posted this week cutting a base which is larger than the width my machine can handle.
the code psted below is my parametric program for making one top rail. if the code works in your machine i can send you other files.
  #12   Ban this user!
Old 08-24-2008, 06:24 AM
re the lathe idea. i have also designed on the back of a fag packet ! a add on unit for my cheapie clarke wood turning lathe (which is hand turn at the moment)
i decided on a horizontal router setup so the z axis wasnt lifting the weight of the router or saw or maybe normal knife just moving it in or out. with a very simple sliding x carriage to hold it. this way i can just bolt the whole lot to the table behind my existing lathe. i have changed the lathe motor for a parvex servo so i can control speed and syncronise for fluting and spiraling.
thats as far as ive got apart from buying servo motors and drives. as it doesnt need to be super accurate i was going to try 12mm threaded rod as my "ballscrew" for this one as i cant afford to keep splashing out on my weird toys.
if this works ok i will convert my fully automatic hydraulic copy lathe which is always in my way and not being used at the moment.
ive been playing with mach3 and it seems like everything i need for most of my ideas. i just wonder how many i will manage to finish!
Need Help!- Biesse rover eng_semsem1980 Commercial CNC Wood Routers 16 12-13-2010 06:16 AM
biesse 325 w/rt 480 control sidskilly CNC Machining Centers 3 12-08-2010 02:12 PM
Newbie- Biesse purchase Bob McGregor CNC Tooling 3 08-15-2008 11:31 PM
Biesse Rover 22 paul sharpe Teachers Hang out 2 10-09-2007 12:50 PM
Biesse eng_semsem1980 Commercial CNC Wood Routers 0 07-26-2007 04:32 AM
