Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 07-25-2008, 04:52 AM
melvillecook is on a distinguished road
cnc-STEP machines Z - S720
Hi there
Firstly, hi to all, I hope somebody can help.
I have just purchased the above said machine, and I'm having problems setting it up, any ideas, I need to set how deep to mill, thickness and length of milling tool, ) points, working area etc. etc. Does anyone have a CNC-step machine if so please help.
Melville
Old 08-18-2008, 06:14 AM
DavidMc0 is on a distinguished road
Hi Melville,
I have the S720, I didn't need to do much to set it up when I received it, I used Mach3 controller software, and BOBCAD for creating toolpaths.
What software are you using? Software, such as BobCAD (or other CAD/CAM software) is needed to create a toolpath that the machine will follow. It's in this software that you determine the depth of cuts, thickness and length of mill tool etc.
Hope you're getting on ok with the machine - I was a complete novice when I received my machine, having never used any CNC equipment or routers/mills before, so hopefully I can help you with any issues you're having!
David
Old 08-18-2008, 07:23 AM
Hi there David
When I bought the machine they suggested using Corel Draw with their CNC machining software (winPC-NC light ) BUT everytime I do a new profect I have to reset the "0 points" the work area / the milling depth etc. Shouldn't it remember everything, eg. it has a work area of 720 x 400 x 110 so its start point etc should remain the same no ?? Me too, an absolute novice, first time, IT WORKS FANTASTICALLY well once I have done about 3 / 4 trial runs and adjusted depth settings, 0 points etc. BUT I MUST DO THIS every time.
I draw my project in Corel draw export it as a plotter HPCL file, open it in winPC-NC light, then I have to go into parameters and setup everything everytime even though I'm working with the same milling bit on the same base with the same thickness of material.
Confused.......................
Can you help
Melville
Old 10-21-2008, 07:03 AM
zamzak is on a distinguished road
I have S1000 for engraving and make just 4 different models all the time.
All parameters is saved with toolpath, and when you load toolpath again, you also load parameters (zero point, tools, depth...).
But first you MUST save toolpath with WIN-PCNC.
Old 10-21-2008, 08:09 AM
Sadly I can't help regarding PCNC & Corel draw, but I can say that with Mach3 & Bobcad I was up and running pretty quickly and have had no problems that have been hard to overcome.
PCNC & Corel seemed like a steep learning curve to me (less intuitive... I'm not very patient sometimes!). Hope you're getting on well with them though!
Old 07-02-2009, 07:10 PM
restos is on a distinguished road
David,
I use Solidworks to design my parts and I want to use MasterCam X2 and mach3 with my Z-1000 machine.
Can you please help my with setup?
thank you very much.
Old 07-30-2009, 08:35 AM
cdesigns is on a distinguished road
Hi Guys,
I'm about to buy this Machine S-720 and I was wondering how good is it?
I'm a graphic designer and Corel Draw is one of the best programs I know, I cant wait to start designing, but I want to know if this machine is worth buying, have any of you had problems with it?
I got laidoff from my work 4 months ago and I need to make a small business out of this machine and my budget is very limited.
Are slant bed machines superior to flat bed machines? Quickers General Metal Working Machines 15 03-28-2009 12:41 PM
Step by step cnc plasma with parts list and links. massajamesb CNC Plasma and Waterjet Machines 8 07-08-2007 10:22 PM
help cnc S720 trx007 General Metal Working Machines 0 11-03-2006 09:39 PM
STEP Four machines anyone? sploo Commercial CNC Wood Routers 4 10-26-2005 12:23 PM
different machines reasonable step rates? fyffe555 TurboCNC 1 02-07-2004 04:53 PM
