Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 07-24-2008, 08:44 AM
Matty Zee is on a distinguished road
Excitech controller quest
This thead has been created to capture the work done to figure out the pinout of the 50pin connector of the RZNC-0501 as used on the Excitech 1324 Router.
So far we know
+5VDC seems to go to pins 14 & 37
Gnd is pin 50 (there may be more though)
Pin 18 seems to be the Cutter Adjustment Device (CAD) input
Pin 32, X axis home input
Pin 33, Z axis home input
Pin 19, Y axis home input
Two TI MC3468's are used between the connector and the motor interfaces.
Old 07-25-2008, 06:48 PM
Kent_Norway is on a distinguished road
A oscilloscope is on it way and should be here next week.
I hope to jog the different axis and log the different pins action.
Update would follow.
K
Old 08-04-2008, 05:13 AM
Oscilloscope received, signal tracing would start today
K
Old 08-05-2008, 06:51 AM
Initial testing started and it is pretty hard to establish a good setup to probe the pins. I turned the BB card upside down and did a test run but it was a little hard. I would bring my laptop with the "Round numbers" on tonight and try to work the machine using the DSP as mentioned.
Any one interested reading this thread?
K
Old 08-05-2008, 09:30 AM
highoctanecnc is on a distinguished road
Exclamation Perhaps I can Save You Some Time
Matty Zee and everybody;
I had this manual of the 0501 lying around. I want you all to have it. There's no sense in you having to chase all those wires down.
The pinouts are on pages 6 and 7. If you are unable to download the file attachment, it can be downloaded from our mirror site at: RZNC-0501 Manual
All the Best to You,
Josh Glenn
www.camaster.com
www.cncexperts.com
P.S. - If this information has been helpful, and you feel so inclined. Josh Glenn accepts voluntary donations through PayPal. Make a Donation
So far we know
File Type: pdf RZNC-0501_manual_courtesy_of_camaster.pdf‎ (451.9 KB, 355 views)
Old 08-05-2008, 10:49 AM
Wow, thank you very much Josh Glenn.
I would do a test tonight to confirm since I have no idea which DSP I have, old or new but I would get back as soon as possible.
Thank's
Kent
Old 08-05-2008, 12:21 PM
Controller version
Kent,
Send me a photo of your handheld and your interface board (the board in the control box that the 50 pin mini connector attaches to). I'll make sure you get the right manual.
Thanks,
Josh
Old 08-05-2008, 06:22 PM
Not more work performed today but..
I did not manage to get my hands on any probing tonight. The main task has been to make that dust shoe working and my 4th axis.
Attached is pic of the BB which is in the machines "engine compartment". We have also discussed the topic in the main thread where I posted pics of the handheld controller : Excitech Cnc Router Purchase
Have you run a machine using a crossover cable and a PC through the BB inside the machine? I had a sneaking feeling that this was the way the machines sold using Mach3 was configured but I have not received any feedback on this from the factory.
Thank's a bunch again.
You're help is highly appreciated and I guess a donation is in it's place if this would work out
Regards
Kent
ID:	64360   Click image for larger version
ID:	64361   Click image for larger version
ID:	64362   Click image for larger version
Old 08-05-2008, 10:26 PM
T
Seems i had my number wrong, i thought the pin numbers wrap around like a DB-25 pinout, but they don't. So with the proper pin number the above become
+5VDC seems to go to pins 14 & 39
Gnd is pin 26 (there may be more though)
Pin 44, X axis home input
Pin 43, Z axis home input
But these still don't agree with Josh's doco. Josh, in the photo, it looks like pins 14 and 39 are connected, but your doco has one at +5V and the other ground. Also, the Cutter Adjsut Device is connected to LED D14, which is easily traced to pin 19 on the photo.
It is possible there are different versions? Were did you get your pinout?
I've been thinking about it a bit more and i reckon it would be far easier to make your own breakout board and replace RZNC-0501 completely... You should be able to source the appropriate connectors (green and orange ones) and connect directly to the motor drives (via appropriate protection circuitry). If you don't, you have to make a custom board anyway as you'll need to convert the parallel port signal into differential signals.
I'll be interested to see how you go Kent. I don't actually own an Excitech but have become familiar with them as i have gone to see Rockets in action numberous times and was hoping to keep up with the developments in case he wanted to change over the Mach3.
Old 08-05-2008, 11:16 PM
Breakout Board Design
Kent,
Yes. I have such a breakout board, and the schematic for building others. Are you looking for something like that? Or, are you happy with the handheld controller?
Josh
Regards
Kent
  #11   Ban this user!
Old 08-05-2008, 11:54 PM
Originally Posted by highoctanecnc View Post
Kent,
Josh
Hey Josh,
You're obviously far more experienced than me with these things.
Did you replace the BB with your own or make a new interface or controller to connect to the 50 pin cable?
Cheers
Matty
  #12   Ban this user!
Old 08-06-2008, 04:44 AM
Kent,
Josh
Josh
I have been pretty happy with the DSP setup for easy tasks, but the system was ordered with a 4th axis support. This was a Firmware update on the DSP and then I had to buy a extra Yako to connect the axis.
The solution gives however a very limited functionality where the 4th axis has to manually be moved with the DSP. No auto indexing and no milling while rotating for 3D work.
So I have been looking for a way to implement this using a PC and possible Mach3. Some have done so with additional BB and I have looked at "The smooth stepper" and also "The Brain" :
http://www.safeguardrobotics.com/def...x?tab=cncbrain
http://www.cnczone.com/forums/showthread.php?t=59763
I did make my own circuit-boards and stuff when I was younger but I really do not feel the eager to pick up that glove again.
So the easiest way would for me to connect a PC through the BB in the machine or possible buy something which some one has been testing out and found working without to much hassle.
I really need the machine to be safe and well functioning but not with a proprietary solution which would make me sitting alone with a problem.
This is the reason for checking the pinouts.
So any solution which is well proved and known is of interest for me.
Regards
Kent
Tags
excitech
Excitech SHM 1530A GraHutch Commercial CNC Wood Routers 4 03-18-2012 09:39 AM
Excitech CNC - Syntec Controller Users BC-CNC Chinese Machines 253 01-13-2012 11:42 AM
Excitech Cnc Router Purchase rocket67 Excitech routers 2597 12-07-2011 03:59 PM
RemainCNC NZ Excitech 1530 router. Big S Excitech routers 215 08-20-2010 05:12 PM
New Excitech SHM1312 machine Kent_Norway Commercial CNC Wood Routers 23 09-30-2008 02:24 AM
